1G Fog Light Issue
andocser
Dec 9, 2003
Potsdam, New York
So one of my fog light bulbs died on my '94 TSi AWD so I bought a set of Sylvania uber-white-expensive bulbs to replace them. I got down on the ground and saw two no screws holding the fog light cover on the housing, but I saw three screws that look like they're holding the lights themselves on the car. I'm assuming I'm going to have to take the the lights off of the car and access the bulb from the back somehow. (Please correct me if this is wrong) The problem is that of the three screws that each light has, the two larger ones, the ones it seems I have to remove, are completley rusted in place. Being a bit of a DIY newbie I'm not sure exactally how to handle this. My questions are these:
Am I approaching this problem the right way or is there some other way to get the bulbs out of these lights that I'm just not seeing?
Assuming that these rusted screws need to be removed, will some WD-40 do the trick or am I going to need to drill em out?
Thanks a lot, and again, please excuse my newbishness. I'll get this down sooner or later ;)
Since one of my fogs were burnt out, I replaced my lights with the Sylvania Silver Stars all the way around, including fogs. I ran into the same problem on one side where the two screws were so rusted in place, they started to strip from the Phillips screwdriver I tried using. I doused the screws with WD40, and ended up using a beefy flat head screwdriver to get them out. You dont need to remove the smaller screw, thats for adjusting the level of the light. I would recommend trying a very beefy Phillips screwdriver or drill bit and alot of WD40.
  • For sale 2g 99 2G parts
    up for sale 2g items! everything came out of a 99 eclipse throttle body 70 shipped stock 450cc...
  • For sale 1991 Mitsubishi GTO
    1991 Mitsubishi GTO JDM Import
    • jesuschr
    • ist dwa
  • For sale 4G63 SPAL 6.5 inch Low Profile Fan - Push
    SPAL 6.5 inch Low Profile Fan - Push $55 + shipping & paypal fees* these are great to use with...
