Power door lock fix $40
I got quoted for the oem actuators for a little over 200 each!
I think the pictures are sufficient enough to explain the retrofitting part of the door lock actuators. The rest is mostly common sense. Make sure to buy some DEI actuators and not some cheap ebay special ones.
I bought them here http://www.autotechs.net/cat29.htm (you'll need one ds-2.1 per door)
Just unplug the connector from the existing door actuator and figure out which two wires you'll need to connect to the new actuator.
If you would like to keep the stock security system intact then you'll need to cut the two wires needed for the new actuator and plug the connector back into the old actuator
Special thanks to Jeremy Ho (WWDGuy) for helping me out
"make sure to have doors closed when testing, wont work if dorrs are open) the green wire on the actuator went to the blue/black, and the blue wire went to the red/blue"
if these are wrong it's not my fault and i don't own that car anymore =( so i can't check it for you...good luck
