the3kgt2
- 46
- 0
- May 8, 2004
modesto,
California
Front 2G 3000gt VR-4 Brakes are HUGE: 4 piston calipers with 12.36" rotors. I think all dsms can install them for only $365. That includes the calipers, cross drilled/slotted rotors, and brackets. pads are only about $40.
3000gt SL brakes are the same as us, right? well these 2g vr4 conversion brackets should bolt right in:
http://www.electronicauto.com/products/2gttbrakeconversion/brackets.htm
and you can buy the 2g vr4 calipers for only $50 each at autozone:
http://www1.autozone.com/servlet/Ui...99|~MITSUBISHI|~3000GT|~1994|~LLT|~7.0|~EA|~V
autozone has a core charge, but i know that if you give them your stock calipers they won't know the difference.
and you can buy cross drilled and slotted rotors for $90 for a pair on ebay.
you WILL have to get bigger rims. these calipers won't fit stock eclipse rims, and sometimes wont even fit some aftermarket wheels
I've got a '90 awd, so this is a huge upgrade for my crappy front brakes... any thoughts?
