420A 2gNT Engine Bay Tutorial
I saw a website for a 4g63 engine bay where the author had listed everything under the hood and showed a picture to match the description. So working off the same Idea I did the same thing for the 2gnt. Now this particular vehicle is an automatic but the engine and emissions components are all going to be the same. I'll eventually get some more pictures up of a 5spd 2gnt.
Second note is that on some vehicles the components are in different locations such as some of the emissions components. But the component design did not change drastically and if you see what one looks like then you'll be able to find yours.
1. Shock tower/Strut tower, strut brace in use
2. Air conditioning service port, high side
3. Air conditioning service port, low side
4. Power steering reservoir
5. Engine Coolant reservoir
6. Cam gear, adjustable cam gear in use
7. Oil filler cap
8. Radiator Cap
9. Power steering pump
10. Oil level dipstick
11. Heater hose/tube
12. Engine motor mount (Car's right, engine's front)
13. Positive Crankcase Ventilation valve (PCV valve)
14. Throttle Body
15. Camshaft Position Sensor
16a. EGR solenoid
16b. EGR valve
17. Washer Fluid reservoir
18. Brake Fluid reservoir
19. Motor Mount (Car's Left, Engine's Rear)
20. Transmission Fluid Dipstick
21. Powertrain Control Module (PCM or ECU)
22a.Fuel Pump Relay
22b. ASD (Automatic ShutDown) relay
22c. Transmission Control Relay
Check out related links:
http://www.dsmtuners.com/forums/showthread.php?s=&threadid=54871&highlight=PCM
http://www.dsmtuners.com/forums/showthread.php?s=&threadid=25902&highlight=brake+light
28. Brake Master Cylinder
29. Brake Vacuum Booster
30. Air Conditioning Filter/Drier (silver round component under hoses)
31. A/C Pressure switch
32. Evaporative Emissions Test port
33. A/C line
34. A/C line
35. Manifold Absolute Pressure (MAP) Sensor
36. Positive Crankcase Ventilation (PCV) Valve
37. Brake Booster Vacuum source port
38. Intake Air Temperature Sensor
39. Exhaust Gas Recirculation (EGR) Tube to manifold)
40. Fuel Rail Test port
41. #1 Cylinder Fuel injector
42. Engine removal support bracket
45. On-Board Diagnostic (OBD2) connectors
45a. Primary, used for generic scan tool
46b. Secondary, used for dealership scan tool
47. Junction Block (Interior Fuse Block)
48. Shift Interlock Cable
49. Brake pedal hinge
