Please Support JNZ Tuning
Street Build DeadlyAKrunna47's Eclipse GSX
Mitsubishi Eclipse GSX
Turbo Type
GT35 Variant
Build Type
  1. Street
Shear Top Mount exhaust manifold
GTX3576 w/ T4 1.06 divided housing
4" Velocity stack intake
3" side exit exhaust
Magnus street intake manifold w/ velocity stacks
S90 throttle body
obx intake insulator gasket
TiAL bov
short route fmic
Dynatek spark amplifier
300m COP w/ ngk BPR9ES gapped to .032"
solid motor mounts
1200cc injectors
Full Blown fuel pump assembly
primary AEM 320lph Fuel pump
secondary Walbro 255lph pump
8AN fuel feed line
6AN fuel return
inline fuel filter
AEM fuel rail
AEM fpr
AEM methonal kit w/100% methanol
jacks alternator relocation
Red carbon fiber from Carbon etics :
hood
doors
cls hatch
center tail light
rear window visor.
Fal lexan rear window
Carbon fiber dash
Carbon fiber door panels
Mods-Engine
2.3L;
Wiseco pistons .020
Eagle rods
100mm Oem crank polished/balanced
oil cooler
ACL race bearings
balance shaft delete
Gates racing timing belt,
Curt Brown 2g Race port head
ARP head studs
COMP 3 cams
GSC SS valves
Kiggly Beehive springs
Kiggly HLA
Bronze valve guides
Competition multi angle valve job
Cometic headgasket
3g lifters
Mods-EMS & Logging
DsmLink V3
Speed density
IQ3 street dash cluster
Gauges:
AEM; wideband | boost | methonal flow |
OHM engine harness
OHM fusebox harness
Mods-Drivetrain
PPG 1-4 Dogbox Transmission
-Magnus Billet shift froks
-Quiafe front dif
- 4 spider center diff
-Straight cut center diff body
-Boostin performance 300m trans output shaft
-All new Mitsu oem bearings
Boostin performance 300m transfer case 25 spline output
ACT Twin disc with 25 spline inputshaft hub
DSS Aluminum drive shaft
DSS Stage 5 rear axles
billet carrier bearing bushings
shift lever ball bearings
Custom super short shifter,
Custom 14 point Roll cage
Sparco ADV seat
custom super short shifter
17x9.5 RPF1 enkies
nitto track 235/45/17r
Baer track brakes
stainless brake lines
TrueStreetTuning Tubular front subframe
Tubular crossmember
Megan front upper control arm
Megan rear trailing arms
chromoly tubular rear subframe
front and rear DC tower bars
RM front & rear sway bars
Parts Wishlist
Wish already came true :D
Background
My car was built from passion, not for others approval.
DeadlyAKrunna47
Comments
Rating
5.00 star(s) 6 ratings
Share this Vehicle
