- Ownership Status
- Currently Own
- Year
- 1998
- Model/Trim
- Mitsubishi Eclipse GSX
- Turbo Type
- 50-trim
- Drivetrain
- AWD
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- Forced performance Black turbo
DNP exhaust manifold
Magnus cast intake
FIC 1650cc injectors
FIC rail
Hellcat pump with 6AN lines all the way around
Tial BOV
Tial wastegate
Treadstone TR1045 intercooler
Evo brembos with the proper knuckles
3G brake master with 2g booster
AEM 5 bar MAP sensor
GM IAT
Mishimoto rad
Vibrant catch can
CNC hydraulic staging brake plumbed through OEM proportioning valve
- Mods-Engine
- Built 7 bolt split thrust long block
Polished Stock crank
Wiseco 9:1 pistons 85.5
Manley H beams
Balance shaft delete
OFH with external oil cooler
Felpro Permatorque headgasket
ARP L19 headstuds
Kiggly steel street springs
Kiggly HLA
BC stock size valves
HKS 272 cams
HKS adjustable cam gears
Evo 3 valve cover
Stock rockers and lifters
- Mods-EMS & Logging
- 97 ECU with DSMLINK V3 full
- Mods-Drivetrain
- Act streetlight flywheel
Southbend stage 3 drag 6 puck clutch
Stock 95 trans with new bearings, shot peened gears, full gear detailing, boostin billet bearing platecentre diff, and shift rails done by TRE. shepherd racing harden steel 1-2 shift fork, 4 spider centre diff using the rear diff crossshaft machined by TRE
Stock LSD axles
95/96 intermediate shaft due to A/C bracket delete
Stock driveshaft with new U joints
NDD driveshaft loop
Magnus billet bearing cover on a stock 91-96 ratio t case
Billet driveshaft carrier bushings
Volk billet rear diff bushings
Stock LSD rear diff
- Mods-Handling
- Megan racing coilovers
Adjustable front upper control arms
3G eclipse tubular rear upper control arms for the rear with poly bushings
- Parts Wishlist
- FD RX-7 rims with Hoosiers
PPG dogbox with the works
Carbon paint matched OEM shaped hatch
Near perfect condition white hood
Near perfect condition white 2G high rise wing
Near perfect front grey leather seats
Full poly bushing for suspension
- Background
- A 2g DSM has been my dream car since I was 5 years old, bought my first one as my first car back when I was 17 ( 1995 eclipse GS ) and I’ve had 5 more ( GST, RS, GSX ) and now I’m on my 6th and hopefully final one. I can proudly say I’ve built the car from the ground up by myself besides tuning it, I’m slowly trying to learn. Goal is to have a perfect white 98 gsx 10 second street car
- 1/4 Mile E/T
- 10.874
- 1/4 Mile MPH
- 135.52
- 1/8 Mile E/T
- 7.154
- 1/8 Mile MPH
- 102.95
- 60' Time
- 1.769
- Timeslip Details
- Canadian 94 pump gas, 35psi of boost, 3100lbs, Indy 500 tires
