Street Build Apollo
Ownership Status
Currently Own
Eagle Talon TSi AWD
Turbo Type
GT35 Variant
Drivetrain
AWD
Build Type
  1. Street
Intake Manifold: Magnus 1g Intake manifold
Blow off valves: 2 HKS limited edition ssqv
Exhaust manifold: Full Race hp coated tubular manifold
Exhaust: 3 Inch turbo back apex-i N1
Wastegate: Tial 44mm
Intercooler: 2.5 Inch thick core aluminum Greddy trust front mount with nitrous express intercooler system
Cooling system: fluidyne aluminum radiator with samco silicon upper and lower hoses, Greddy s type overflow tank, and FAL dual slim fans
Oil system: Greddy oil catch can system custom oil cooler in driver front bumper cover all steel braided lines
Turbocharger: Modified Garret Gt3582 with upgraded cartridge to the .82mm wheel A/R .72 to keep compressor in efficiency over 600hp with faster spool 35r housing, polished hpc coated
Mods-Engine
Engine Built by Slowboy Racing
6 Bolt 2.3 Stroker balance shaft eliminated
Piston/Compression Ration: 8.8:1 85.5mm (.020 over)
Manley I Beam clevite main and rod bearings
Camshafts: HKS 280/280 cam HKS adjustable cam gears
Valves/springs/retainers: Manley valves, Manley titanium retainers, Manley springs
Cylinder head mods: 6 Bolt hot tanked and pressure checked race port and polish, comp plus 5 angle valve job, Mitsubishi 4 layer metal head gasket
Head/Main studs: ARP L19
Intake Manifold: Magnus 1g intake manifold
Fuel Injectors: Fuel Injector clinic blue max 1450's
Fuel delivery: walbro 255 lph in tank lifter pump ->swirl pot ->Bosch 044 -> aeromotive inline fuel filter->AEM rail ->aeromotive FPR -6 AN fittings and push-lock lines.
Ignition System: Aem "smart coils"
Mods-EMS & Logging
Standalone AEM EMS #2
Mods-Drivetrain
Clutch/Flywheel: Exedy 6 puck sprung race clutch ACT lightened flywheel (8lb)
Transmission: Sheptrans stage 4, custom aluminum/polyurethane rear trans mount Driveshaft shop stage 4 front axles
Shocks: F&R: k-sport control pro series full coilovers with 36-way adjustable dampening dc sports front and rear strut bars
Wheels: 18x8 Tenzo dc-6 v2 flat black with red stripe
5x114.3 bolt pattern, aluminum racing lugs, +35 offset
Tires: Falken 235/45/18 rt-615 drag radials
Brake lines: Stainless steel braided
Parts Wishlist
Not Much, run race gas thru then potentially newer turbo, injectors, fuel cell, dual fuel pumps, roll cage.
CarNage
More from CarNage
Share this Vehicle
