Sirius1995
- 425
- 92
- Jun 15, 2021
Hattiesburg,
Mississippi
So rebuilding 160k miles virgin 7-bolt block for daily use but I want it to be reliable and long lasting and mostly stock, other than 16g and fmic.
Which bearings I should buy?
I read the forum that ACL is most recommended.
I don't think nothing has gone up with the size, so I assume I can run standard size bearings?
There was options for extra oil clearance so should I buy those or bone stock ones, for me it sounds better to have more lubrication on crank and rods but is there down side for that why I shouldn't get ones with extra oil clearance?
And I still have balance shafts on, should I get rid of them since they're not that necessary and buy the delete kit or should I just buy a new set of bearings and belt and keep them?
If you have any suggestions or recommendations just let me know.
Ps. I'm trying to use OEM parts as possible, as much as my paychecks allows me to
