my_precious
- 454
- 0
- Jan 19, 2004
Jackson,
Michigan
http://cgi.ebay.com/ebaymotors/2X-R...33725QQitemZ8030717901QQrdZ1QQsspagenameZWDVW
There is a link to a pair of Ralliart 4 pt harnesses. Here is my question:
I've read up on this a little bit, and I havn't been able to reach a solid answer. As far as I know, any type of aftermarket raceing harnesses are meant for track use only. Due to whiplash and whatever else, they are not suitable for street use. They are designed to be used with a Helmet and Haans device.
HOWEVER, I've seen a lot of dsmers on here with race belts and I've had people tell me that as long as the belts are mounted above your sholders you're good. Another thign I've heard is that the stock seat belts can also give you whiplash and brake your neck etc.
OK, that being said....I can either buy racing harnesses now, or I have some canadian belts lined up already that I can use. Either way, I need belts because the previous owner of my car has removed all of the electric belts and pieces. I DO NOT want unsafe belts, but then again I am going to use this car for track days and possibly rally raceing, as well as my daily driver. So, harnesses would be nice. I dont have a mounting bar, or a roll cage yet, and wont for awhile. I just want to know if I should wait and buy some harnesses (possibly those ralliarts) or buy the Canadians.
To make this even more clear:
Which is safer, standard car seat belts (3pt), or 4pt-6pt Raceing Harneses for STOCK aplications (no roll cage, helmet, haans, etc...could get a harness bar though)
