MorrisonFab
Supporting Vendor
- 315
- 1,073
- May 28, 2017
Johnson Creek,
Wisconsin
Being able to fit a TiAL Sport/Xona Rotor internally wastegated (IWG) turbo in nearly every DSM/Evo1-3/GVR4/CSM engine bay was exciting, but to also have an IWG setup without needing to relocate the alternator or oil filter has us pretty thrilled. We've had our eye on their IWG housing for a long time since it has an inconel diffuser/sleeve at the turbine outlet to smoothly rejoin the wastegated/bypassed exhaust, an IWG port sized between a 38mm MVS and 44mm MVR, and was overall designed to bypass a large portion of exhaust when needed. And, of course, their scrutinized dimensions all around that allowed us to clear all the various mounts/brackets as-is. We went in determined to make it work, even if it was for limited applications, but it all fit beautifully. Even allows just enough room for a nice puller fan with the larger X3C cover on our Colt (verified nearly identical radiator space as Evo 1-3). 1g and 2g DSMs will have even more room since the design was based off our "compact" manifolds meant to tuck everything close and clear tighter engine bays. Not having to relocate the alternator means AC can be retained, and it passes the oil filter test so it can be spun on and off with everything else in place.If you’re looking for extra low boost, or to get every last psi from the compressor, then an externally wastegated setup may still be better suited; but within the boost range the turbos already like to be in, the TiAL IWG housing is perfect for people looking for a simplified, extremely well packaged and already recirculated setup to keep the exhaust more subtle under full boost. Plus, even with the pricier IWG housing, it ends up being ~$200-400 less overall vs an external setup.
The entire setup, including turbo with package pricing, can be purchased directly through us, and allows us to install all IWG components so it's ready to drop in.
The gist of it:
-Maintains all OEM accessories such as A/C, alternator in the factory location, power steering, and still spin the oil filter on and off.
-Efficiently supports 800whp+ and ideal for the entire IWG Xona line of turbos, from the XR 4948 to the XR 8264S.
-Uses small primary runners to aid in quick spool, transient response, and aggressive midrange.
-Gains of 50 ft-lbs. of torque throughout the midrange power curve are not uncommon and well suited for spooling an auto car or transient response between shifts.
-All fitment done with the with the X3C compressor cover, more room available with the X2C.
-Fits Evo 1-3, Galant VR4, 1g, 2g, 6 bolt, and 7 bolt. The main puller fan must be a slim fan on Early Evo and Galant VR-4’s/Colts/Mirage.
DSMs will have lots of radiator/fan room, with 2g’s able to fit the OEM main fan.
-Galant VR-4’s will require a different lower intercooler/charge pipe routing since this manifold wasn’t designed for the “over the top” OEM style charge pipe routing above the exhaust manifold.
-Equal length runners and a proper small volume merge collector.
-321 Stainless, 100% fully backpurged.
Cheers,
Annika and Matt
Manifold only: http://morrisonfabrications.com/product/compact-iwg-xona-v-band/
Manifold and hot parts: http://morrisonfabrications.com/product/dsm-evo-1-3-compact-iwg-xona-hot-parts/
