AustinGST98
- 43
- 4
- Nov 1, 2016
East Hampton,
Connecticut
Hello,
I am currently installing my Kelford BSE kit because I didn’t want to beat up the oil pump with a stub shaft.
The bearing on the back of the balance shaft from the oil pump normally is fed oil from the balance shaft itself (it’s hollow and fed from the pump), and the bearing has no hole unlike the other two.
I got my BSE kit from STM and there is a hole in all 3 bearings. Is anyone familiar with this? I feel like I may have clearance issues with this hole in the bearing. See photos below.
Wondering if anyone has experience, and if i should run the bearing with a hole or try and source a new one.
