Looking to get rid of my 1993 Talon TSI AWD Automatic 108k on the body. Located in Central Ohio, it would need towed away. Open to any offer; either she'll get some life from a fellow enthusiast or I'll donate her to some children's charity. Looking to get it out of here as quickly as possible.
Car has largely set untouched for 15 years, minus a couple starts and attempts for me to get her running condition again. I just haven't had the time or desire unfortunately after starting a family.
Of importance it has a rebuilt 4G63T 6bolt engine with 0 miles on it installed - other then starting it a couple times - in which it ran/sounded great last time I did so. It also has a JDM transmission that I was told had ~30k miles on it - mostly installed (I think I have the original Auto transmission too if you want it as well).
The interior/exterior is not in good condition, was dinged a couple times, headliner is falling, couple burn marks from previous owner. A lot of interior panels were taken apart - I have stuffed everything I could find into the trunk. It could use a good cleaning that's for sure.
Most of the engine/drivetrain is assembled, what would be required is: wiring up some electronic connectors on the transmission (I don't recall if I finished this), basics like all fluids flushed/refilled, intake reassembled (included in trunk), maybe new tires, new battery, random electrical connectors and hoses that probably need reconnected, whatever random troubleshooting from age, etc etc.
Any questions or requests let me know. I'm not really interested in parting out the car, I have no time to work on it to pull it apart nor do I want the shell to remain at my home. Please plan on towing her out of here. All offers will be entertained but I don't have time to haggle so be reasonable.
I'll try to list everything I've done to the car in the past ~25k miles of her life prior to becoming dormant, however I'm possibly forgetting or misremembering things, so I cannot guarantee the accuracy of the list. Also, there are no guarantees or warranties implied on anything. Buyer takes full responsibility to inspect and agree to everything in it's current condition prior to purchase and towing the vehicle.
![talon_engine.jpg talon_engine.jpg](data:image/svg+xml;charset=utf-8,%3Csvg xmlns%3D'http%3A%2F%2Fwww.w3.org%2F2000%2Fsvg' width='200' height='150' viewBox%3D'0 0 200 150'%2F%3E)
![talon_front_driver.jpg talon_front_driver.jpg](data:image/svg+xml;charset=utf-8,%3Csvg xmlns%3D'http%3A%2F%2Fwww.w3.org%2F2000%2Fsvg' width='200' height='150' viewBox%3D'0 0 200 150'%2F%3E)
![talon_rear_passenger.jpg talon_rear_passenger.jpg](data:image/svg+xml;charset=utf-8,%3Csvg xmlns%3D'http%3A%2F%2Fwww.w3.org%2F2000%2Fsvg' width='200' height='150' viewBox%3D'0 0 200 150'%2F%3E)
![talon_interior.jpg talon_interior.jpg](data:image/svg+xml;charset=utf-8,%3Csvg xmlns%3D'http%3A%2F%2Fwww.w3.org%2F2000%2Fsvg' width='200' height='150' viewBox%3D'0 0 200 150'%2F%3E)
- Engine rebuild from cali shop - 0 miles
- imported JDM transmission - 30k miles
- imported JDM TC attached to transmission - 30k miles
- rebuilt turbo
- evo3 exhaust manifold
- custom downpipe
- fuel pump
- spark plugs
- spark plug wires
- short ram air intake
- intake manifold cooling gap gasket
- strut bars
- tie rod ends
- LCA bushings
- 4x new shocks/struts
- new axles
- brake pads
- all new calipers
- ss brake hoses?
- brake flush
- ECU rebuild
- new lights everywhere
- alternator
- starter
- trans control solenoids
- trans filter
- TC flex plate
- trans flush
- oil pan
- pcv valve
- valve cover replacement, + gaskets
- racing fluidyne aluminum radiator
- higher pressure coolant cap
- gas cap
- removed AC
- boost gauge on A pillar
- winter tires
- wheel balance
- 4 wheel alignment
- diff and TC flush
- wipers
- oil
- drive belts
- new crankshaft pulley
- numerous interior panels and misc parts (like window motors) replaced from junkyard
- 4x alpine speakers
- silicone rebuilt engine mounts
![talon_engine.jpg talon_engine.jpg](https://www.dsmtuners.com/data/attachments/715/715811-e4bc2f99188dbffc2cbfd401fbbfcd73.jpg)
![talon_front_driver.jpg talon_front_driver.jpg](https://www.dsmtuners.com/data/attachments/715/715812-fc063292cef892b41b5d93842c05487f.jpg)
![talon_rear_passenger.jpg talon_rear_passenger.jpg](https://www.dsmtuners.com/data/attachments/715/715813-4a2656be5586860bd33d6f9cfe279727.jpg)
![talon_interior.jpg talon_interior.jpg](https://www.dsmtuners.com/data/attachments/715/715814-07a3a8b1df9cc5b0e94363f76e7d16f9.jpg)
