1993 Mitsubishi Eclipse GSX Vehicle Profile & Build Thread
92tsifwd's Eclipse GSX
93 awd: XDR 2500lbs clutch, Fidanza 7lb flywheel, b/shafts elim, BC 280's, k&n, ram air intake, 3.5"maf-t, Air to Water ic, w/ short 3" full ic piping, 75mm tb, Dejon SMIM, ported/polish head, ud crank pulley, S.S. T3 header, Garret GT3582R w/ .82 a/r, 44mm Tial wg, 3" turbo-back exhaust w/ cutout, tailor wires, a/m boost, water & oil gauges, ecm link v3, translator ver. 2.02, 8 gal poly fuel cell, -8 fuel line & return, mallory 110 gph inline fuel pump, mallory afpr, FIC 1150cc inj, water/alcohol injection 300cc nozel, slim pusher fan, 160* t-stat, battery moved to trunk Ext oil cooler, Prothane motor mounts. 86 fox hatchback GT40P engine full bolt ons! 90 Talon awd dd: super 20g, 3" turbo back, 2g maf, fmic, eprom, 255hp, hard piping, PTE 1000cc inj
Mods-Engine
6-bolt, ballance/s elim, flow bench ported and polished head by Green cylinder heads, stainless steel valves, Viton valve stem seals, BC 280's, BC dual valve springs & titanium retainers, ARP head studs, 4 layer metal head gasket, kevlar timing belt, 2g pistons .20" over bore, Clevite tri-metal bearings, stock polished crank, 90 oil cooler
Mods-EMS & Logging
Eprom, Maf-t ver. 2.02, DSM Link ver. 3, 8 gal poly fuel cell, -8 fuel line & return, mallory 110 gph inline fuel pump, mallory afpr, PTE 1000cc inj,
Mods-Drivetrain
built 23 spline with double syncro 2nd gear, steel shift forks, welded center diff, viscous elim, fwd pass axle, SBR twin disk clutch, Fidanza 7lb flywheel, 1 piece driveshaft, redline shock proof lube
16"x7.5" Weld Racing wheels with 4 225 45r16 Nitto 555R Drag radials,
obx coil overs, 93 BIG breaks upgrade, kyb agx front struts
Parts Wishlist
8.8 solid rear end, 26"x9.5" hoosier QTP slicks on 15's, dogbox, forged internal 2.3 short block, bigger turbo
1/8 Mile E/T
8.952
1/8 Mile MPH
80.450
Timeslip Photo Link
Timeslip Details
Track Name : Karney Raceway Park
Nitrous : No
Fuel Used : Pump gas
Vehicle Weight : 3100
Tires : Drag Radials
Altitude : 2130
Sponsored Car : no
0.0 lb/ft
Dyno Session Details
Nitrous : No Nitrous
1G DSM
92tsifwd
More in 1G DSM
Share this vehicle
