Please Support RTM Racing
Please Support STM Tuned
1G Wastegate vacume line routing
BoostedS256
42
7
Oct 11, 2018
Olympia, Washington
I’ve only ever dealt with manual boost controllers that have two vacume ports so just want to make sure this is correct. Line goes from controller to a t which drops down to the IC pipe and other line goes to wastegate, in the picture my finger is pointed at the line running to the controller.Also should the other three ports on the wastegate be closed off or left open like they are? Thanks
Dang sorry didn’t even think to search turbosmart for the anwser thank you, yeah I know the wastegate isn’t the best option but for know it’s not leaking and is holding 32psi fine. But will def get a tial sooner then later.
So should the other bottom port and two upper ports just remain open like they are?
