Please Support RTM Racing
Please Support STM Tuned
Various DSM PARTS & 7 Bolt parts
DSM_ThuNDeR
565
4
Feb 28, 2008
Salinas, California
Hello guys I have some stock DSM parts up for sale, little aftermarket. If you are interested in anything, let me know. Thanks for watching! If its "1g" its a TURBO SIX BOLT PART.
<b>ALL THE 1G TURBO PARTS:</b>
- Oil Filter Housing
http://i79.photobucket.com/albums/j132/venom_greenbeast/oilfilterhousing2.jpg
http://i79.photobucket.com/albums/j132/venom_greenbeast/Oilfilterhousing.jpg
- Power Transitor
http://i79.photobucket.com/albums/j132/venom_greenbeast/powertransitor.jpg
- Modified TURBO water pipe
http://i79.photobucket.com/albums/j132/venom_greenbeast/1gwaterpipe.jpg
- Water Neck
http://i79.photobucket.com/albums/j132/venom_greenbeast/1gwaterneck.jpg
- TPS
http://i79.photobucket.com/albums/j132/venom_greenbeast/1gTPS.jpg
- TURBO Intake Manifold
http://i79.photobucket.com/albums/j132/venom_greenbeast/1gIntakemanifold.jpg
- Fuel Rail w Regulator
http://i79.photobucket.com/albums/j132/venom_greenbeast/1gFuelRailW1gregulator.jpg
- Coil Packs (2)
http://i79.photobucket.com/albums/j132/venom_greenbeast/1GCoilPacks.jpg
- CAS
http://i79.photobucket.com/albums/j132/venom_greenbeast/1gcass.jpg
Both look like a nasty color, but WORKED GREAT
- BOV
http://i79.photobucket.com/albums/j132/venom_greenbeast/1Gbov.jpg
- Block driver side motor mount w power steering bracket
http://i79.photobucket.com/albums/j132/venom_greenbeast/1g6boltblockmountwpwrsteeringbracke.jpg
- Various TIMING PARTS
http://i79.photobucket.com/albums/j132/venom_greenbeast/1Gtimingparts2.jpg
(Consists: (2) Lower Tin covers, Oil pick up tube, tensioner arm, ANOTHER motor mount, hydrolic tensioner, balance shaft belt sprocket, Crankshaft sprocket w bolt and plates.. ect)
- Six bolt turbo pistons and RODS in good condition
(NO PIC SORRY)
<b>NOW FOR THE 2G TURBO Parts!</b>
- TOTAL SEAL piston rings(2nd GAPLESS, 9_1 Compression!) used for 35 MILES! WOW.
http://i79.photobucket.com/albums/j132/venom_greenbeast/TOPSEALPISTONRINGS.jpg
- JDM EVO 3 Valve Cover painted black(CHIPS HERE AND THERE) - 65
http://i79.photobucket.com/albums/j132/venom_greenbeast/JDMEVO3Valvecover2.jpg
http://i79.photobucket.com/albums/j132/venom_greenbeast/JDMEVO3Valvecover.jpg
- 7 BOLT(yes 1g 7 bolts will fit), ARP HEAD STUDS.... ONE NUT WAS LOST DURING UNINSTALL, extremepsi.com had them for less then 5 bucks each! - 30
http://i79.photobucket.com/albums/j132/venom_greenbeast/ARPHEADSTUDS.jpg
- 7 Bolt facing Foward OIL FILTER BRAKET w gasket(NEVER USED)
http://i79.photobucket.com/albums/j132/venom_greenbeast/7BoltFacingfowardoilfilterbraket2.jpg
http://i79.photobucket.com/albums/j132/venom_greenbeast/7BoltFacingfowardoilfilterbraket.jpg
- o2 Housing
http://i79.photobucket.com/albums/j132/venom_greenbeast/2go2housing.jpg
- 2g MAF - 45
http://i79.photobucket.com/albums/j132/venom_greenbeast/2GMAF.jpg
- Intake Manifold
http://i79.photobucket.com/albums/j132/venom_greenbeast/2gintakemanifold.jpg
- 95-96 intake cam gear
http://i79.photobucket.com/albums/j132/venom_greenbeast/2Gintakecamgear.jpg
- Injen Short Ram intake ORIGINAL, NOT A REPLICA! - 90
http://i79.photobucket.com/albums/j132/venom_greenbeast/2ginjenintake2.jpg
http://i79.photobucket.com/albums/j132/venom_greenbeast/2ginjenintake.jpg
- Fuel Rail
http://i79.photobucket.com/albums/j132/venom_greenbeast/2gFuelRail.jpg
- 7 bolt FIDANZA FLYWHEEL (For AWD DSM), needs new center piece.. used for 3K! - 90
http://i79.photobucket.com/albums/j132/venom_greenbeast/2GAWDFIDANZAFLYWHEEL.jpg
- 95-97 Thottle Body (NO TPS OR IAC)
http://i79.photobucket.com/albums/j132/venom_greenbeast/2g95-97TB.jpg
- <b>7 BOLT BLOCK!</b> Spun one rod bearing. (hardly could hear it though, should be fixable!) 10K miles with new: water and oil pump, bse kit. - 250
http://i79.photobucket.com/albums/j132/venom_greenbeast/2G7BoltBlock.jpg
Comes with everything you see here excent oil dipstick/tube.
<b>89-99 DSM PARTS</b>
- A.C.T. Clutch disk used for ~6K
http://i79.photobucket.com/albums/j132/venom_greenbeast/ACTCLUTCHDISK.jpg
- OEM CLUTCH DISK! BRAND SPANKIN NEW!
http://i79.photobucket.com/albums/j132/venom_greenbeast/OEMCLUTCHDISK.jpg
<b>MISC</b>
- Hx35 8 bladed hotside w actuator
http://i79.photobucket.com/albums/j132/venom_greenbeast/Hx35hotside.jpg
http://i79.photobucket.com/albums/j132/venom_greenbeast/Hx35hotside2.jpg
FOR NOW that is all I want to sell to fund my 6 bolt swap ;) If you like something, Call or TXT ME with your best offer, the prices I put up are for the VALVE COVER, ARP head studs, Injen intake, 2G Maf, ACT FLYWHEEL, and the 7 Bolt block, for everything else BEST OFFER TAKES IT. Thanks for viewing!
831-794-7408
Tony
mitsubishi Eagle talon eclipse gsx gst tsi laser plymouth seven bolt six bolt dsmlink keydiver fftec rre honda diamond star motors toyota turbonetics garrett holset 16g 20g hx40 hx35 gt35r gt40r 4g63 compa trini
