Please Support STM Tuned
Please Support Rix Racing
turbo oil drain cheap fix
Ok I know you can just buy a kit that will do this but I cant a ford it right now so I came up with this I hope it will work fine I dont see why it wouldn't so here you go let me know what you guys think. I had to do this because neither my 14b drain or my t25 drain would fit it was as if they weren't long enough.
Parts:
5/8 heater hose about 1 1/2 foot long
2 hose clamps
old 14b oil drain
new gaskets
Tools:
10mm socket
ratchet(I used Quarter inch drive)
extension
5/16 socket or flat head screwdriver
cut off wheel
pb blaster or wd40
here are the steps I did,
step 1) Remove drain tube or find old one
step 2) Put drain in vise or hold on very tight and cut about 2 inches from the flange on the straightest part, then cut just after the bend on the other end so that it is straight as possible.
step 3) Put those two ends on the turbo and oil pan, it dont really matter which one goes where(with new gaskets or silicone).
step 4) Spray the turbo side and put your hose up on it for a mach up then put the hose to the pan right next to the other flange and cut it so that when you push it all the way on it wont kink or bind up.
step 5) Leave the turbo side on and slide both the clamps on and tighten down the turbo side, then spray the pan side and put the hose on and clamp it down
Now if its kinked at all I would start all over. With the hose I mean. LOL I have pics just cant figure out how to put them on here. if any one could help me ill put the pics up.
