Moparbishi
- 112
- 0
- Sep 15, 2007
Fremont,
Nebraska
Hello, I am trying to get to the bottom of why my 98 talon doesn't want to read the proper throttle position sensor voltage. It reads around .23v with my foot off the pedal and around .86 wot. I can offset the tps on dsmlink by 200% and it essentially doubles my voltage, but still only reads 33% throttle when I am flooring it, obviously causing it to run like crap.
The tps sensor is good, even tried swapping with a know good one. I did the ohm test between the terminals on the tps and it checked out good. I also sent the ecu in dsmlink and it tested ok on their bench tester. I also tested for continuity at the ground coming off the tps pigtail and I have a good ground.
The voltage for yellow/red (IPS switch) was reading 4.76v at the tps and the harness coming off the ecu. The brown/red (tps output voltage) was reading .23v foot off the throttle and .86v wot.
Now I tested the voltage of the green/yellow wire (+5v sensor power) at the tps pigtail and the pigtail straight out of the ecu and it only reads 1.05v. I believe this is where my problem lies, I just cant figure out why there is only 1.05vs coming out of the green/yellow wire.
