ileagleracing
Supporting VIP
- 328
- 191
- Sep 27, 2007
OKC,
Oklahoma
After mangling my strut tower bar & radiator frame structure winching the car on the trailer, I need to mount a tow strap. Any suggestions as to where to put it?
Note: This feature currently requires accessing the site using the built-in Safari browser.
You could get a bulfab crossmember or maybe a similar one.You must be logged in to view this image or video.
Ive used Rennline universal kit, comes with a nice tow hook that screws into a mount which is bolted to my crash beam.
Ive been towed many times off track with out a issue, even with dragging the brake to keep tension in the tow line.
The car only rolled freely 2 out of the 3 times I used the winch this year.
I'm going to try this, worst case I mangle a crash beam?
I do plan to replace the bolt that came with the strap for a longer one.You must be logged in to view this image or video.You must be logged in to view this image or video.
How is that mounted??Here's how I did a tow hook. The rear mount is done the same way.
Not really, but if it wasn't any lighter than OEM & didn't provide any performance advantage, probably wouldn't get protested over it.Samuel, are you allowed to run an aftermarket crash beam in your class?
