MehoFaca-GSX
- 0
- Apr 30, 2012
waterloo,
Iowa
DSM
97 mitsubishi Gsx AWD Turbo on E85 ethanol
140k on body
magenta Gray color factory paint the body is great shape no rust never been in a accident has clean Title
it has nice 17" tsw black rims with kumho all season tires on it
suspension has not been messed with or lowered it is stock
car still has that original feel to the car like it did when it was new still
has power steering
only thing removed was the A/C
I have Paperwork photos to show what ive done to the car since ive owned it etc
The car does not run right at this moment
i need to finish putting the motor back together and in the car only it needs
gasket set
head gasket
timing belt
rod and main bearings
And time i dont have to put back in the car
THIS IS WHAT SHES GOT UNDER THE HOOD
I MAY BE FORGETTING SOME THINGS FEEL FREE TO ASK ?????'S
Man Trans Built Transmission and transfer case
OEM flywheel
NEW clutch
new race motor mounts
ENGINE IS A 1 GEN 6 BOLT 4G63T
HEAD- work was done by machine shop
1mm oversized ferra valves
supertech race valve seals
beehive dual valve springs
titanium retainers
new oem oil lifters
FP4R cams
aem cam gears
powder coated valve cover
new seals
Arp Hardware
BLOCK- was stress tested sand blasted re surfaced and bored 20 over to fit the pistons and painted to match the valve cover
Arp rod and crank hardware
oem balanced crank
CP FORGED 20 over pistons
H Beam forged rods
new front cover with oil pump
water pump etc
3 DOWNPIPE
3 INCH APEXI EXHAUST ALL THE WAY BACK
FP DSM Race Exhaust Manifold
BIG PTE 6262 TURBO
TIAL External wastegate with dump pipe
Greddy blow off valve
giant front mount aftermarket intercooler and piping
had intake manifold port and polished by shop
4 inch injen intake to turbo
bosh 255 fuel pumps
fuel lab fuel pressure regulator
1500cc injectors
chevy 350 MAF
Aem 2.5 bar sensor
Mishimoto radiator with 2x slim fans
aftermarket catch can
manual boost controller
Dsm link V3 i have the tuning program and cable to go with it
Has 3 slot gauge pillar with
wideband air to fuel
boost
oil pressure
FEEL FREE TO OFFER i know i am forgetting stuff
IF I WAS TO TRADE ID BE LOOKING FOR A MANUAL RWD CAR INTERESTED IN A MAZDA RX7 NISSAN 240SX OR A BMW E30 DEPENDING ON CONDITION MUST BE MANUAL!!!
ANY QUESTIONS
CALL OR TEXT
956-324-3747
140k on body
has power steering
gasket set
head gasket
timing belt
OEM flywheel
NEW clutch
titanium retainers
new oem oil lifters
FP4R cams
aem cam gears
new seals
Arp Hardware
oem balanced crank
H Beam forged rods
water pump etc
3 DOWNPIPE
BIG PTE 6262 TURBO
bosh 255 fuel pumps
1500cc injectors
chevy 350 MAF
Aem 2.5 bar sensor
boost
oil pressure
ANY QUESTIONS
CALL OR TEXT
956-324-3747
