Please Support Morrison Fabrications
Please Support ExtremePSI
2G The Red Demon kicks off 2016 with a Bang - 192 MPH!!
What you think?
If you tried to just muscle it out the big end and do it with trap speed, it would be more like a 500 shot. I bet a 50 shot would only net 1-2mph on the big end and barely touch the ET.
Shep is the only one we can bench race with, as he made passes both ways. I think he went 7.90@191 without nitrous and 7.70@196 with. I don't know how big of a shot it was but I'd imagine it was 100+
He's making enough power right now to do it, it's just trying to get the car to front half better. Rau went 6's at 200mph, but he had like 1.0 60's.
It's incredible that we can even entertain the thought of a 6s awd dsm. If these guys keep pushing I think we'll see it in 2 years. I just hope it happens ay Byron and I'm there to see it.
build the car your way and not follow the cookie cutter concept this is what has inspired me over the years to do the same with results!!
You realize the only reason the autos are the norm/way to go now, are because someone decided "screw the cookie cutter dogbox idea, I'm going with this POS auto". :p
Also, keep kicking ass Boostin'. So good to have new faces continuing to push the envelope. Please don't stop like the "other" guys did.
Wow my comment had nothing to do auto???
I see that you have beat us to the punch in adding the video to this thread. ;)
**UPDATE**
Over the Memorial Day Weekend, we took the Red Demon out for some testing on the new Methanol Injection and 83mm Turbocharger setup. After putting down over 1300WHP on our Mustang Dyno, we were itching to see her fly down the track!
We're thrilled to announce that the Red Demon captured (2) records over the weekend.......
World's Quickest & Fastest 4 Cylinder AWD
and Quickest & Fastest H-Pattern Manual Trans!! [email protected]! :hellyeah:
First Pass - 7.55 @ 195.9 MPH
They say records are made to be broken... so we broke our own and backed it up with an 7.4 at almost 200mph!!! ROFL
7.46 @ 199.9 MPH
The Red Demon was not at full power for these passes, as we just switched fuels and are still collecting data on the Haltech Elite 2500. We expect to go quicker and faster, so stay tuned!!
Visit our website where you can purchase many of the EXACT SAME PARTS used on the Red Demon!
ENGINE:
(*) Boostin Performance Red Demon Spec Short Block -
http://shop.boostinperformance.com/product-p/bp-reddemonsb-dsm-short-block.htm
(*) Boostin Performance Stage 3 Cylinder Head w/ Custom Kelford Cams
(*) Boostin Performance 1/2" L19 Head Stud/Insert Kit w/ Custom Copper Head Gasket
(*) Magnus Motorsports V3 Bad Ass Intake Manifold
(*) Straightline Performance / Turbo Joe Custom Exhaust Manifold
DRIVETRAIN:
(*) ShepTrans / PPG 4-Speed H-Pattern DogBox Transmission
(*) Boostin Performance 300M Upgraded Transfer Case & 300M Transmission Output Shaft
(*) Quarter Master Custom Triple Disc "Drag Clutch" (available exclusively thru Boostin - will be on our website soon)
(*) Driveshaft Shop HD Driveshaft & Stage 5 Axles
CHASSIS / SUSPENSION:
(*) Magnus Rear Sub-frame Modified for 3000GT Rear End / Sway Bar
(*) Custom Tubular Front Sub-frame
(*) KYB Struts w/ Custom Springs
(*) TMZ Performance Rear Brake Kit
(*) STMtuned.com Front Brake Kit
(*) Volk TE37's w/ 26" Slicks
INDUCTION / TURBO:
(*) Precision Turbo & Engine 8385mm Turbocharger
(*) Precision Turbo & Engine 64mm BOV
(*) Boostin Performance 3.5" Custom Upper Intercooler Pipe ( Vibrant Performance Materials)
(*) Extreme Turbo Systems 6" FMIC
(*) K-Tuned 90mm Throttle Body
FUEL SYSTEM / ENGINE MANAGEMENT / IGNITION:
(*) Sparktech Ignitions DSM Drag II Ignition System
(*) Haltech ECU Elite 2500
(*) Kiggly Racing 12 tooth crank trigger
(*) 4 Fuel Injector Clinic 2150cc Injectors
(*) 4 Precision 5000cc Injectors
(*) Aeromotive Mechanical Fuel Pump
(*) VP M5 Methanol
(*) Custom 2 Gallon Fuel Cell Behind Passenger Side Headlight
EXTERIOR:
(*) Angry Aero 2G Bumper Shutters, Mirror Deletes & Custom Front Lip
(*) X-treme Graphics & Lettering Decals
1307 WHP / 844 WTQ
Solid Line = New Setup
Dotted Line = Previous Setup (ET of 7.78)
I believe it's just the 1-4 H type pattern as their dogbox is 4 gears according to their mod list. I'm curious as well though for the thorough description LOL I'm looking forward to the shootout! Hopefully it's nice and cool and we see 6's! Maybe head to head match up too for good funn :hellyeah:
Will you guys please clarify what you mean my H pattern for those of us who just don't know. Thanks.
H pattern is the standard shift pattern in regular transmissions. As opposed to a sequential which is still a manual but clearly not an H. A standard 4 speed with no reverse would make a perfect H. You can see where the name comes from.
A picture is worth a thousand words:
With sequential it's not possible to select the wrong gear.
Thanks JT! Us street guys have a hard time sometime understanding track terminology! LOL
I am impressed with this. So we are saying that the DSM AWD 5 speed (4 speed in this case) trans (ppg dogbox) is the fastest h pattern shifted car in the world? It seems very ironic to me that this is true as I have destroyed and have seen so many others destroy these transmissions. They are notorious for being sh$%%y- and yet its the fastest. I think its awesome- but kind of funny at the same time.
Congrats!
Congrats!
This is not a stock gear, it's ppg straight cut dog box. The only thing stock is the housing. Check their mod list. It no longer rely on stock gears.
By "H-pattern" we're referring to the standard shift pattern, as JDT posted a picture of for reference.
If you watch the in-car video, you can see Devin moving the shifter to go into reverse and 1st gear, not forward and backwards like a sequential shifter. He doesn't use a 5th gear for drag racing, just 1-4 - 5th gear is used more for when he does 1/2 mile events in the Demon.
Hope this help clarify things :thumb:
Yes sirrrr. Thanks
So when do we get to see you break your 1/2 mile record. Or I could just say when is your nest half mile event?
So when do we get to see you break your 1/2 mile record. Or I could just say when is your next half mile event?
Not certain about 1/2 Mile events....been concentrating more on 1/4 mile :D
Boosting.
I have a questions. What radiator setup are you running?
It's a custom radiator setup designed to fit the Red Demon.
