Please Support JNZ Tuning
Please Support ExtremePSI
The Quest For Low Amp Draw
Vehicle : 1987 Mitsubishi Starion ESI-R
LED CONVERSION PART 1 "FROM SUPER BRIGHT LEDS"
Reg bulbs
194 = 270 MA x3
1156 = 2.10 Amps x6
1157 = 2.10 Amps x6
27mm Festoon 0.100 MA x3
26.31 Total Bulb Amps
L.E.D's
194 = 160 MA x3
1156 15 SMD = 350 MA x2
1156 26 SMD = 470 MA x2
1156 3x2 = 260 MA x2
1157 26 SMD = 250 MA x6
27mm Festoon .055 MA x3
4.30 Amps
THE REMOVED BULBS "BIG AMP DROP"
BULBS ON THE LEFT VS LED'S ON THE RIGHT "PARKING LIGHTS"
TWO BULBS AND FOUR LEDS
ALL BRAKE LED's
BOTH DOORS AND DOME GOT THEM TOO
FRONT PARKING LIGHTS ARE EXTREMELY BRIGHT
FRONT PARKING LIGHTS ONLY, NO FOGS!!!!!!!
Invoice from Led Conversion Part 1
Youtube video of my car after the install cause alot of people on a SQ facebook group wanted to see it. Note: The fogs ARE NOT ON! Car was also off so its battery voltage ONLY!!!
Part 1
Part 2
Trucklite L.E.D. specs:
Low Beam (top on) - 1.80 Amps - 1300 Lumens
High Beam (both on) - 3.60 Amps - 2600 Lumens
Current bulb - 60/55w:
Low Beam - 4.58 Amps - 910 Lumens
High Beam - 5 Amps - 1500 Lumens
http://www.drivetrainamerica.com/p-...ar-led-5-x-7-truck-jeep-xj-yj-headlights.aspx
Also using this headlight harness which provides another 1.5 to 2 volts to each headlight. Whatever the alternator output is, is what the harness gives the headlights. Its plug and play. One plug hooks into the factory harness so the stock buttons work, hook up power and grounds then each plug at the headlight.
http://www.eautoworks.com/Putco-H4--9003-Heavy-Duty-Headlight-Upgrade-Wiring-Harness-PRD7540.aspx
Led Flasher and its silent so no clicking.....
https://www.superbrightleds.com/mor...12anl-01-led-bulb-electronic-flasher/781/835/
