bastarddsm
- 5,620
- 1,458
- Aug 26, 2003
Mendota,
Illinois
Heres a few ideas for you guys to play with. build a 2.4 using a 4gcs and a 4g63 head. I belive this creates a 11:1 compression ratio. then use the cyclone intake with the butterflys working for better lowend torque. switch to a turbo computer and such, it really isn't hard you only have to add 3 wires, and you get the benefit of a knock sensor and being able to burn eprom chips. Keep your n/t trans low gears are your freind with a low torque motor. You guys will never make enought power to tear up a n/t trans. thats what i run in my turbo car and there simply isn't enought traction to break it, and it is just as strong as a turbo. but avoid spinning one tire cause that will cause it to spit a spider gear out into the belhousing. (this is why i have a n/t tranny now)
