Mitsubishiown
- 194
- 17
- Feb 11, 2012
Davison,
Michigan
I have seen great reviews about TCE's customer support and being willing to talk with you to find the correct setup for your needs but I have not read much about STM or the difference between their lightweight drag kits. I assume they are essentially the same. TCE is a little cheaper for the standard scalloped rotor and I assume the only difference between the two kits is the brake lines and potentially the mounting hardware. Anyone with experience with either of these have advice? Getting them to reduce weight with better braking, plan on using a 3g master cylinder, doing ABS delete, and fitting them with a 15'' wheel.
