Please Support Morrison Fabrications
Please Support STM Tuned
914 Cheeko
Jul 10, 2018
Newtown, Connecticut
What if someone were to just replace their suspension with solid bars rather than coilovers/shocks for a race-only car? It would be the stiffest suspension possible, as well as reduce the weight of the car slightly. Would it be worth it for the cornering? Would there be any pros to using this? The cons are obvious; low traction, extremely harsh ride quality, and possibly damage to other components of the car. What type of racing, if any, would it be useful in?
Why would anyone want to do that?
Having ZERO suspension travel would be bad. It would make for a very harsh ride and it would lessen the cornering ability. Ever driven a gocart? Remember how easy it is to spin one out? Just now you have much more momentum and it's gonna hurt worse.
The only racing I could see it being useful in would be a sled pull truck or tractor. That's it
Want to feel what this is like? Riding an old wooden cart with just wheels attached to spindles gives the same feeling.
The car would bounce all over the place and every tiny little bump, losing Tire contact with the road, resulting in zero traction, resulting in broken stuff or a car that goes into the wall and is terrifying and uncomfortable to drive. Lack of travel or range of motion through this suspension would also result in terrifying cornering sequences, due to change in contact patch pattern, resulting in even less traction combined with the pumps.
At the very minimum you would want some kind of rubber bushing to absorb some of the impact, but that's still going to suck massively.
May I ask what raises this question?
Yeah this would be a bad idea. Some suspension travel is definitely needed. The go kart analogy is fairly accurate, but a go kart would actually have more suspension action than this. A karts chassis isn't connected in the back by a tube. But a piece of flat bar that actually tunes the flex of the chassis. But with a car, literally the only suspension travel would by the sidewall of the tires flexing. And wherever the chassis breaks LOL. Definitely no motorsport where this would be beneficial.
