Dennyj1992
- 37
- 0
- Jun 21, 2012
Bay City,
Michigan
Sorry if I'm posting this in the wrong section. Still getting used to the site around here.
Back on subject... I know this has been asked before because I just googled the same question, but why the hell is my 420a so slow? I did find some information here: http://www.dsmtuners.com/threads/slow-420a.378933/ and from there, I did everything that was included in a tune up except for my fuel filter and coil pack (plus wires).
My car is a 1997 Eagle Talon ESi with the automatic, so my problem is the same as the OP's in that thread. My take off from a stand still just flatlines. I can't even spin the tires. So last night I took her out for a cruise down a back road and decided I would try a little test. So I stopped and pulled out my stopwatch. From a stand still (with my overdrive on) I brake launched it right around 2300 RPM (as high as I could get it in an auto) and let her rip from there. Nice pull between 4-6k or so, but it still felt too slow. So anyways, I ended up FINALLY hitting 60 mph, and as soon as I did, I hit stop on the stopwatch. 13.9! I mean c'mon! I know the auto's are slow and even worse is that the torque curve is all mid-top range power but that's slower than my grandma's 99 Saturn SL1 automatic, !
Here are some troubled problems that could be causing it:
Front end tie rod ends are getting a little worn.
The muffler is rusting on the inside and sounds a little loud.
My O/D was on.
The bend pipe from the exhaust manifold down to the exhaust under the car is rusting and has a hole in the top. It's getting louder by the day. I had the exhaust re-welded all the way back from the where the catalytic converter should be (it was removed and the car was straight piped) with brand new exhaust pipe. One spot he didn't weld quite right, so it needs to be gone over again quickly. It's a very thin, small leak.
Coil packs are older and I'm not sure about the fuel filter.
CEL is ON. I unplug the battery and it shuts off for a few days, then comes back on at random. O2 sensor maybe?
Mods and tune up:
New plugs
Seafoam through the crank, gas and compression lines. Nice smoke show!
Oil change right after. 5w-30 with Lucas oil stabilizer.
Warm Air Intake w/ cone filter
Spare tire and board from the trunk removed.
Sorry for the long read, I just want to make sure I'm including all the info needed to better diagnose the problem here. Thanks guys, I really appreciate any input and help received.
My O/D was on.
Mods and tune up:
New plugs
