mnim15
- 162
- 8
- Mar 16, 2008
Duluth,
Minnesota
Moving all my DSM inventory I’ve been hoarding for the last 10 years.
Valve covers (Pictures Attached) $90
*$75 with cracked spark plug cover bolt holes
Used transfer case $100
freshly powder coated black chrome 1G fuel rail $15
New CXRacing same side intercooler (Pictures Attached) $70
Spearco 221 intercooler (Pictures Attached) $70
New FP3 Cams (Pictures attached) $300
Shells:
*These will be pulled out of storage early summer and pictures added
Clean white 98 awd converted with brand new rear subframe fully sound deadened interior
98 spyder completely gutted awd swapped at some point
Red 95 awd lowered needs engine and transmission
Rusty 97 Black awd shell
99 Spyder GST silver w/ black leather wife's car its a little rough
Drivetrain:
Half a dozen 1g awd transmissions in various states
Quite a few various transfer cases
A few 2g awd transmissions
I have a couple 2g rear diffs too
Fuel system:
A couple sets of injectors mostly mid sized fic
Engine:
2.4l eagle wiseco both torn down and honed crank polished (Pictures Attached)
A couple 2.0l 6 bolt short blocks
A few sets of cams
Evo behive springs and retainers
Good used ARP headstuds (missing some nuts and washers)
Several new sets of EngnBldr 3G lifters
New OEM rocker arms
After markets springs and stainless valves
Several 2g and 1g heads
Several radiators stock and aluminum 1g and 2g
I will be updating this with more specifics and pictures as I go through my garages.
I have most things you could think of to complete a few fully built cars.
Located in Duluth, MN if anyone wants to come check out in person.
Prices are plus shipping and fees unless otherwise agreed upon.
ALL ITEMS ARE NEGOTIABLE!
Thanks
-Matt
Texting works best!
Call/Text: 218-461-5023
SOLD:
New FP V1 68HTA
2X DSMLink V3 Full
DSMLink V3 Lite
Used FP3 cams
Used SuperTech Dual seats/springs/retainers
New SuperTech low profile valve seals
New EngnBldr 3G Lifters
2G Brembo Bolt-Up front knuckles with ABS Sensors
2G FMIC Delta Core, Stainless J-Pipe, Aluminum upper/lower, Tial BOV, silicone coupler/t-bolts
Used Good MHI small 16g
Uncracked 1G Valve Cover
Used Gold Fuel Lab Filter and Regulator kit w/ black lines
2G Jacks Ultimate Synchro transmission
New 2G SPC Adjustable Upper Control Arms
New black Fidanza cam gears
New Crower Springs and Titanium Retainers
Used silver Fidanza cam gears
Silver Fidanza cam gears
New Crower Valve Springs and Ti Retainers
New SuperTech valve guides
Used Crane Cams 43-0012
1X G4CS Machined Block/Crank Wiseco Piston/Eagle Rod
New ACL race main and rod bearings
New Wiseco Piston rings
New Kiggly main girdle
New ARP main studs
New 6-Bolt AWD Fidanza Aluminum Flywheel
Koni Yellow Eibach Pro-Kit Assembled <1K Miles
MHI 20G with FP 8CM DSM Turbine Housing <1K Miles
2G Ported/Polished Machined Head Assembled w/ New Supertech Valves, seals, and Dual-Springs
2G AWD 3” stainless turbo back exhaust
AEM Electronic Wideband
AEM Electronic Boost Gauge (50psi)
2G dual pod gauge cluster bezel
2G Thermostat Housing
2G Power Steering Bracket
2GB CAS
6-Bolt Wiseco/Eagle Short Block
Used HKS 264 Cams
New DG Coil Over spring rates 700/350
Shells:
Drivetrain:
Fuel system:
Engine:
A few sets of cams
New OEM rocker arms
Thanks
-Matt
Texting works best!
SOLD:
New FP V1 68HTA
2X DSMLink V3 Full
DSMLink V3 Lite
Used FP3 cams
New ARP main studs
2GB CAS
Used HKS 264 Cams
