Please Support STM Tuned
Please Support ExtremePSI
Selling an unmodified 1995 eclipse gsx in great shape, documented services for 15yrs!
L8knight
Nov 27, 2017
Rutland, Vermont
Call/text 603.913.3603 car is in Rutland VT
1995 Mitsubishi Eclipse GSX AWD TURBO! Rear find, this is an unmodified, stock all the way down to the factory radio with equalizer! 148,137 on the odometer, HOWEVER, documented records for motor and transmission replacement at mitsubishi dealership totaling nearly $8,000.00 which only has 45K miles since! This vehicle is fully equipped with leather, cruise, power windows/locks/mirror, sunroof that works, fog lights that work, rear wiper that works, rear defrost that works, automatic, and more. Minimal wear in seats, carpet and dash, considering the age, it's in great shape, no rust on the body either! Prior owner was a female professional that kept every documented service to this car, totaling over $14,000!
Current Mileage is 148,137.
-Transmission rebuilt at 103,593 @ Manchester Mitsubishi ($2,789.17)
-Motor rebuilt (NEW MOTOR) at 103,648 @ Commonwealth Mitsubishi ($5,150.35)
In the last 10,000 miles the following has been done to this car
- 4 NEW TIRES
- Alignment
- All 4 Ball Joints
- Control Arm & Assembly
- Front pads and rotors
- Water Pump Pully
- A/C Belt
- Air Filter
- BG Brake Flush
- Coolant Flush
- rear wiper
- Valve Cover Gaskets
- Washer Clips and line
- Fuel system clean
- Exhaust work and muffler
(All of the above are documented, totaling over $4,000)
This car was well cared for, and it shows. I just drove this for 3 hours straight on the highway and route 4, and was a dream. Drives straight, smooth, and stops on a dime with no shaking. No leaks, no warning lights such as abs or check engine etc.
