hazzard74
- 5
- Apr 9, 2017
Forest Grove,
Oregon
My intake cam gear is bent and needs to be replaced. I did check to make sure it was torqued and seated well.
I just put the motor in with a new timing belt, etc and really don’t want to go through all that again.
I’ve read some threads regarding swapping cams without taking the timing belt off. Is there any reason I couldn’t do the same with the cam gear?
