4gfun
Supporting VIP
- 2,009
- 55
- Dec 10, 2007
Ask Me,
Virginia
AFAIK the rear brakes on a GVR4 are the same as a 1g. The questions may be a bit granular, so please don't not answer because you don't have all the answers.
1) I just ordered 2 rear reman calipers from advance auto and noticed that the 2 bleeder screws are the same size on those calipers. However, the left rear caliper bleeder I removed from my GVR4 is thinner and has an 8mm head. The passenger rear bleeder size is thicker like the 2 replacement calipers and has a 10mm head. I normally wouldn't care, but I am running speed bleeders all the way around. The thought of having to research and then purchase/wait for one 10mm bleeder screw does not appeal to me. What gives?
2) I have done the rear brakes before and I am having a super hard time with them this time around. I have read that removing the rear parking brake cable makes things easier. I kind of wish that I didn't remove the cable ends. This puts the boots at a risk of tearing and one has torn.
3) There are numerous shims that came with the pads. I got 2 on one side and 7 on the other. I counted 7 shims on the right side. I can't remember how they go.
Anyway, is there an order of operations as to how to replace the rear brake pads? I purchased semi-loaded calipers and I am scared to put the pads in and then have them fall out after connecting the parking brake and stainless steel brake line which is very rigid and turns with the entire line.
Thanks for any help!
