jamel16
- 289
- 247
- Aug 6, 2004
Richmond,
Virginia
So here is the problem I’m having ,I can’t seem to bleed my rear brakes. I have a vacuum bleeder ( mityvac) and I also bought the one that uses an air compressor from harbor freight and nothing works. This is what my brake system consist of rebuilt 3000gt front calipers, rebuilt oem rear calipers, SS lines front and rear, Jnz abs delete kit, 3g brake booster, 3g master cylinder ( brand new), 1g oem proportioning valve ( brand new). For the life of me I cannot bleed the rear brakes, it feels like something is blocked or locked up. I attached the mityvac, applied vacuum to 25psi, cracked the bleeder and nothing happened. The gauge just stayed at 25 psi. I researched and found that this could be caused by a bad proportioning valve, so I swapped out my brand new one for a couple of used units I had laying around. There was no change. I performed all the bench bleeding processes by the book. I’m totally lost and frustrated on this one. Any help would be appreciated.
