Mosebrosdsm
- 0
- May 18, 2015
Devils lake,
North_Dakota
So basically got the 97 eagle talon tsi on a little road trip. I’ve taken this car on 8+ hour trips with no problems. Sorta broke down a couple times having a weird electrical issue is what I think. Not sure tho. Basically doesn’t matter if it’s in town or cruising everything is running great then bam the revs drop drastically, rpm gauge will show different rpm range than I’m in. Bogs way hard like there’s no spark. But there is just at around 1/10th the power. I replaced the coil pack with one I found in this town I’m stuck in thinking that was the problem since that’s one of things I havnt replaced on this car yet. Got about 100 miles outside of Billings and started doing it again. If I let us sit a couple minutes it will start right back and I can keep driving for a while then it will do the same thing gahhhbh. Also I keep pulling up the same DTC a multiple random misfire code. I’m stumped I’m really lost. And I’m also stuck!! HELP!!
