JAW91
- 131
- 5
- Dec 16, 2008
Orlando,
Florida
I have had a pretty bad oil leak for a while now (I have a 95 with a 6 bolt swap) spraying from the back of my motor somewhere, I have no idea where it is comming from but I have replaced the hose and pcv valve from the intake manifold to the pcv valve on the valve cover. I have also heard there was a bolt that blocks off a passage that goes all the way through to the motor where the intake manifold bracket goes but I have stuck a screwdriver in all the open holes I could find and none of them have gone through. I took some pictures of how bad the leak is then cleaned it off the rear subframe (it leaks on the rear subframe, axles, exhaust, and about half way down the bottom side of the car). and took a video of it sprinkling on the rear subframe from the spraying that is comming from somewhere under the intake manifold. What I'm getting to is where do you guys think this leak could be comming from?
MAH01828.mp4 video by Carparts26 - Photobucket
