1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Trouble Logging In or Staying Logged In?
    CLEAR YOUR BROWSER COOKIES! More info about this can be found here. If you still have trouble after clearing your browser's cookies and cache, reply to that thread and tell us what browser you're using and what device you're using.
November Porting Special @ Boostin Performance
Posted by Boostin Performance, Nov 1, 2018
Please Support Jackson Auto Machine
  1. Boostin Performance
    Boostin Performance Supporting Vendor
    216
    227
    Joined Jan 7, 2014
    Hoffman Estates, Illinois
    For the entire month of November, we are offering 5% off our Porting Services!!!
    Porting is a detail often overlooked or forgotten about, but not at Boostin Performance. Buying the best turbo on the market will only get you so far. Cast components tend to be rough which can cause excessive turbulence and ultimately rob power from your set up. By removing these irregularities and smoothing the casting, you'll increase the flow capabilities of your set up!! Porting your cylinder head, manifolds, and/or turbocharger is a detail you don't want to ignore as the smallest detail can make a difference. smilie_thumbsup.gif
    Extreme attention to detail is taken with our porting services. With our intake manifolds, the runners are gasket matched, the porting goes deep into the runner, and all of the bumps and irregularities on the inside of the plenum are removed or smoothed out. A Ported Stock Intake Manifold also serve as a stealthy way to keep that stock appearing engine bay look.
    Our Porting Services include, but are not limited to:
    -Turbo
    -02 Housing (Cast Only)
    -Exhaust Manifolds
    -Intake Manifolds
    -Throttle Body
    -Cylinder Head Porting
    Sale ends 11-30-2018
    Contact us if you have any questions regarding this service such as what can be ported, and pricing!
    Log in/Register to remove ads
    My DSM:
    1996 Eagle Talon TSi AWD
    Drag Race Build
    7.04 @ 205 MPH
    Loading...
    ErikTande likes this.
    Featured Products from our Supporting Vendors
  2. Boostin Performance
    216
    227
    Joined Jan 7, 2014
    Bump!
    My DSM:
    Drag Race Build
    7.04 @ 205 MPH
    Loading...
  3. Boostin Performance
    216
    227
    Joined Jan 7, 2014
    Bump!!!
    My DSM:
    Drag Race Build
    7.04 @ 205 MPH
    Loading...
  4. Boostin Performance
    216
    227
    Joined Jan 7, 2014
    TTT!
    My DSM:
    Drag Race Build
    7.04 @ 205 MPH
    Loading...
Share This Page
Loading...
Log in/Register to remove this ad
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Tire Rack VR Speed Factory White Shed Speed
