1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Trouble Logging In or Staying Logged In?
    CLEAR YOUR BROWSER COOKIES! More info about this can be found here. If you still have trouble after clearing your browser's cookies and cache, reply to that thread and tell us what browser you're using and what device you're using.
New 1G products coming soon
Posted by 99gst_racer, Jun 4, 2017
Please Support Kiggly Racing
  1. 99gst_racer
    99gst_racer Moderator
    8,984
    663
    Joined Apr 5, 2003
    Coloma, Michigan
    Hey guys,
    I've had a chance to prototype a few new 1G products lately, and I wanted to chime in to share and also to gather some opinions. I still need to test this stuff on a few cars before it's available. But once available, I will have ads in the Freelancer section.
    I'm working on a 1G rear upper control arm. These will offer a greater adjustment range and also save around 1.5 lbs weight on the car. These are similar to the Afco DIY kits that some people have been using. The differences are that my arms will have a stronger tube, a much better heim joint, and properly fitting standoffs that won't require modification. The inboard end will feature a chromoly, teflon-lined heim. The outboard end will be a very nice Moog tie rod end (booted and zirked). The tube itself is a large OD extruded aluminum tube. Very strong due to it's hex shape, and reasonably lightweight as well. Pricing will probably be around $200 shipped for the set.
    I'll also be offering a 1G active toe eliminator kit. These will feature a chromoly, teflon-lined heim. I'll also be including 4 small round caps to use to weld over the factory bolt holes. I'm hoping to be around $150 shipped for the kit, so reasonably competitive.
    And last but not least, I'll be jigging up a 1G rear subframe in the coming weeks. I'll be designing and building a prototype tubular rear subframe very soon. And there will be options for a 1G rearend or 3000GT rearend. I'm very much looking forward to this project. I hope some of you guys still want something like this.
    Anyway, that's all I have for now. Feel free to post any suggestions or opinions you may have. I welcome any constructive criticism. And if there's another 1G rearend product you want, let me know.
    Thanks!
    Log in/Register to remove ads
    My DSM:
    1999 Mitsubishi Eclipse GST
    Street Build
    609.8 whp   541.2 lb/ft
    Loading...
  2. Geeb
    Geeb Proven Member
    357
    38
    Joined Apr 6, 2016
    Philadelphia, Pennsylvania
    Sick man
    So glad after all these years still new gear breakin out of the wood work..
    Way to go boss.
    My DSM:
    1990 Eagle Talon TSi AWD
    Drag Race Build
    GT35   manual
    Loading...
  3. 19gsx91
    19gsx91 Proven Member
    903
    256
    Joined Apr 20, 2011
    Walworth, New York
    I'm definitely interested in the control arms! looks good
    My DSM:
    1992 Mitsubishi Eclipse GSX
    Street Build
    292 whp   264 lb/ft
    Loading...
    99gst_racer likes this.
  4. Puller
    Puller Proven Member
    228
    18
    Joined Feb 7, 2003
    Rochester, New York
    I'd be interested in a tubular subframe so long as you can retain a rear swaybar.
    My DSM:
    1991 Eagle Talon TSi AWD
    Street Build
    14b   manual
    Loading...
  5. Vegas smith
    Vegas smith Proven Member
    1,990
    877
    Joined Dec 2, 2002
    Houston, Texas
    Sweet. Go ahead and sign me up for the tubular subframe. And who do I make that $150 check to?
    My DSM:
    1993 Eagle Talon TSi AWD
    Street Build
    GT30   manual
    1992 Eagle Talon TSi AWD (sold)
    16g   manual
    Loading...
    iugrad92turbo and 99gst_racer like this.
  6. 99gst_racer
    8,984
    663
    Joined Apr 5, 2003
    Coloma, Michigan
    Retaining the rear sway bar will definitely be an option.
    My DSM:
    Street Build
    Loading...
    dsmspickdad likes this.
  7. Puller
    228
    18
    Joined Feb 7, 2003
    Rochester, New York
    I'd be curious to see how you do it. I've been kicking the idea around for a bit but I always gave up at the lower control arm swaybar mounting situation. Thanks for even putting any effort into the 1g stuff. Even though many moved on to Evo's and GTR's and such, there's still a few bitter 1g graybushes like me that refuse to conform. "Get off my lawn you kids!"
    My DSM:
    Street Build
    14b   manual
    Loading...
  8. gsxeclipse102
    gsxeclipse102 Proven Member
    529
    124
    Joined Mar 8, 2003
    carmel, New York
    Ill deff take a tubular subframe. By any chance will you ever consider building a front subframe also? Also rear lower control arms with sway bar attachment would be nice :sneaky:
    My DSM:
    Street Build
    GT35   manual
    Loading...
  9. yokotabrat
    yokotabrat Proven Member
    435
    23
    Joined Mar 11, 2004
    Northglenn, Colorado
    My DSM:
    12.705 @ 107.660 MPH
    Loading...
  10. DetroitStroker
    DetroitStroker Proven Member
    176
    38
    Joined Dec 22, 2012
    Detroit, Michigan
    X2 on a front subframe!
    gsxeclipse102 likes this.
  11. 99gst_racer
    8,984
    663
    Joined Apr 5, 2003
    Coloma, Michigan
    Sorry guys, I have no plans to do a front subframe at this point.
    My DSM:
    Street Build
    Loading...
  12. 99gst_racer
    8,984
    663
    Joined Apr 5, 2003
    Coloma, Michigan
    Thanks for the link. Is everyone else having the same problem with a straight upper arm?
    I could definitely offer a bent version. I'd use 4130 tubing, bend it in my bender, and weld in threaded ends. It would have to have a double adjuster for adjustment, and I'd also have it powdercoated. Definitely doable, but it would add around $70 to the final cost.
    As far as options and quality goes, I can offer just about anything - I'm just afraid of going overboard and putting out an overpriced or overly expensive product. I try hard to run that fine line between quality and affordability, but I err on the side of quality in most cases.
    My DSM:
    Street Build
    Loading...
    JondoeDSM likes this.
  13. Meech Meimaris
    Meech Meimaris Proven Member
    59
    11
    Joined Jul 15, 2014
    Hackensack, New Jersey
    I need everything, can you do the Toe in pieces for me? I can weld but you certainly do the work I am willing to pay for. Would you be interested in doing this for me?
    Thanks
    Meech
  14. Puller
    228
    18
    Joined Feb 7, 2003
    Rochester, New York
    I am not 100 percent sure but I think some problems stem from a crappy heim in combination with a full suspension cycle? I have the straight ones currently with no problem, however I haven't gone to Watkins Glen yet so I don't know how they will like track-use. I don't really understand why heim joints are used in the first place other than you can buy them off the shelf with the correct threads for the swag tube used. I rather have an oem style bushing end.
    What if you nix any finishes/powdercoating? Negligible cost difference?
    My DSM:
    Street Build
    14b   manual
    Loading...
  15. 99gst_racer
    8,984
    663
    Joined Apr 5, 2003
    Coloma, Michigan
    I don't mind offering a welding service for them. But I don't think most people would be interested due to the hassle and costs of shipping the knuckles back and forth.
    My DSM:
    Street Build
    Loading...
    Meech Meimaris likes this.
  16. 99gst_racer
    8,984
    663
    Joined Apr 5, 2003
    Coloma, Michigan
    I assume it has a lot to do with his specific ride height and available suspension travel.
    Heims are great for suspension components. 3-axis movement without bushing deflection. And the threaded connections allow for quick, easy, and infinite incremental arm length adjustment. But you definitely want to avoid the carbon steel, economy heims.
    Nixing powdercoat won't make much difference. It's all in the materials. I spend more money on two tubing ends than I do a threaded suspension tube. Plus the price of 4130 tubing and a 4130 double adjuster. And then a labor cost...
    My DSM:
    Street Build
    Loading...
  17. donk
    donk Proven Member
    105
    4
    Joined Dec 17, 2002
    kalmar, Europe
    How about rear trailing arms like racefab does for the Evo 1-3 ?
  18. Meech Meimaris
    59
    11
    Joined Jul 15, 2014
    I don't mind shipping back and forth, there is no substitute for competent welding, sent you a PM as well.
    Meech
  19. 99gst_racer
    8,984
    663
    Joined Apr 5, 2003
    Coloma, Michigan
    I haven't seen it. Got a link?
    On a 1G, the "trailing arm" is built onto the knuckle. For my subframe kits, I planned to cut it off, plate it up, and go tube forward. The downside is that it would require everyone to send me their knuckles for modification.
    My DSM:
    Street Build
    Loading...
  20. gsxeclipse102
    529
    124
    Joined Mar 8, 2003
    carmel, New York
    How about the lower rear control arms but with sway bar attachment?
    My DSM:
    Street Build
    GT35   manual
    Loading...
  21. 99gst_racer
    8,984
    663
    Joined Apr 5, 2003
    Coloma, Michigan
    I working on that now. I'll definitely have something for that by the time I have a finished subframe kit. But I'd like to be able to offer those arms prior to getting the subframe done.
    I have materials purchased and I have a 1G in my driveway now. Hopefully I have something to show you guys in the coming weeks.
    My DSM:
    Street Build
    Loading...
    GST with PSI and gsxeclipse102 like this.
  22. donk
    donk Proven Member
    105
    4
    Joined Dec 17, 2002
    kalmar, Europe
    Bryan 93 likes this.
  23. lasthope05
    lasthope05 Proven Member
    837
    176
    Joined Mar 31, 2006
    Be careful of using adjustable lower control arms if you dyno your car. Most places will place the ratchet straps on the lower arms and I've heard of a few occasions where the the arms snapping in half.
    Also having an option of a bushing would be nice. Heim joints are horrible for street driven/daily drivers. They wear out and get sloppy incredibility fast.
    Puller likes this.
  24. pagosa dsm
    pagosa dsm Proven Member
    308
    10
    Joined May 7, 2005
    pagosa springs, Colorado
    I have rear tubular control arms top and bottom. I also have the heim joint trailing arms. I did it myself years ago. I mounted the sway bar to the trailing arm with out any problems. If you check out my profile and photos you will see my modds.
    Rick
    My DSM:
    12.084 @ 118.930 MPH
    Loading...
  25. iugrad92turbo
    iugrad92turbo Proven Member
    10,318
    331
    Joined May 22, 2007
    Kalamazoo, Michigan
    Great Paul almost ready for my cross member parts.
    Loading...
Share This Page
Loading...
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Kiggly Racing Magnus Motorsports Miller Import Parts Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Tire Rack VR Speed Factory White Shed Speed
