perez84
- 0
- Nov 28, 2012
merced,
California
Note: This feature currently requires accessing the site using the built-in Safari browser.
Do u know where I can get a connector for the evap purge solenoid? Or a part number? Mine is damaged... trying to get this check engine light offWhats up guys i need help figuring out how these wires go. the red on top or on bottom or if you can show me a pic of the wires on the clip so i can see how they go. these werent even attached they popped right out.
Where did u buy you connectors... maybe I’ll do the sameI'm not sure if it's exactly the same, but this connector might be it, or close enough to work with.
I bought a few different ones when I repaired mine and my brake fluid level sensor connections. Looked like someone bagged one of Ripley's bad guys.....
Connector
