Please Support ExtremePSI
n/t 4g63
wudnt b very effective the compression is lower on turbo pistons than the non turbo pistons....might work good and be cost effective if u know what ## doing and bolt a turbo on and tune it right.....but without a turbo u wud probably lose power
Yup. You need more compression with the N/T. If you're going to do that, might as well CAM it. ;P
It'd run... but it'd certainly be a bit slower than a stock N/T. If you're doing Turbo internals, you might as well turbo it.
