92AWDHX40
Supporting Member
- 13,613
- 1,570
- May 22, 2007
Kalamazoo,
Michigan
Thanks for the update its been a while looking good with the swain tech coating.
Note: This feature currently requires accessing the site using the built-in Safari browser.
Where are the engine bay shots with the CF intake?
It's an Evo IX OFH and if you search it's thread the install is in here. I'd do it quick but I'm on my phone.Can you provide some insight on your oil filter housing? Never seen one in that orientation. Looking good!
Eric, where did you find that sleeving purchasable in the amounts you needed? I'm only seeing 50' bulk options on their site.
Love this build thread. Keep it up.
No joke, my favorite DSM of all time. Not to take away from some awesome shops with great drag builds, but your car is more up my alley. I envy you.
Thanks for the info! Awesome build. Lots of hard work and dedication.
Thanks for the link, Eric. That's definitely a better alternative to the DEI fire sleeve and looks like it's built for higher temperature too. Have you had a chance to do an temperature logs since you installed the heat blankets that TPP built for your turbo setup? I ask because I picked up a TPP manifold blanket and noticed a big difference in coolant temperature increase/change after installing it. Wondering if you noticed similar results.
Car looks good, when's the next track event you plan on attending?
Maybe I've noticed a change with the manifold blanket then because I run a cooler t-stat, 154* Mishimoto. Typically, without the manifold blanket, my CT's would rise to 190* and hangout there at idle but once I get up to speed (40mph+) my CT's would drop to around 165-170*. After I installed the manifold blanket my CT's, even while I was idling for 10m sitting in the Taco Bell drive thru after I installed it, CT's never rose about 180*. With no proof of why, I just attributed it to the manifold blanket doing a better job at controlling heat soak of the waterpipe, radiator, and upper radiator hose than what the ceramic coating did by itself.My oil temperature is higher than usual since I don't have a cooler at the moment, but I didn't notice any change in the coolant temperature. On the street, coolant temperatures have never been an issue for me. At the HPDE I was running up around 235-240F pretty consistently forcing me to ease up on the straights to not go over that. I'm currently working on a radiator upgrade and proper ducting, so I'm hoping those combined with the blankets do the trick. If not, I'll be forced to put a hole in the hood.
Brian and I signed up for the PittRace HPDE event again this year (just one day this time). I'm hoping to get back to PittRace in May for a shorter day to shake the car down and see if it overheats. And there are plenty of autox events throughout the year starting in May that I'll try to get to.
Says the guy with $2k worth of alignment tools for corner balancing? Just saying. hahaIn general, I've started to change my way of thinking about the car a bit. As much as I'd love to pick up all the sweet suspension bits that our freelancers are putting out I realize that they won't make go around the track significantly faster. What is my best bang for the buck at this point to have fun with the car and put down consistent lap times? I'm to the point now where I have plenty of power for my skill level, the brakes should be adequate for anything I can throw at the car, and it's still a clean street/track car. So I'm not really interested in going all-out with projects to take away from the fun of driving it or spending a lot of money on things that I could spend elsewhere.
My wishlist at the moment is:
Another set of wheels (still use street tires, not interested in going to R comps since I'm not competing)
Racetech RT4009 seats
Harnesses/mild cage (just so I can use the harnesses)
Those are some pretty pricey pieces!
