Papedouze1979
- 0
- Dec 3, 2018
Dartmouth , ns,
NS_Canada
Hello, I have a eagle Talon 1997 tsi I removed my engine 7 bolts to change my rod bearing after my piston. My engine is out of the car and transmission. the motor head is separating to the motor. just take off hand bolts. I remove the oil pan ect .. the question: when I reassembly the bottom and the top, I have picture of Before and after disassemble each step. for the timing belt I do not want to be wrong. he has a way to check everything for the piston in the right place in relation to the head. (I have nothing to do with the head, it's going to be exactly like when I dismount it.) (This is the bottom I play with the piston to remove rod bearing. ?)(For put the timing belt and down with up , you have god idea or procedure for check all fit? i have manuel for the car .i have spec for rod ect . )_
I put them back as on my picture? or another idea?for sure is good ? test?
