Chuck Boone
- 0
- May 16, 2018
Visalia,
California
Hi DSM tuners,
Been working on a very stock '90 Eclipse 1.8L as a project car for/with my kids to get them learning about cars and mechanical things. Definitely outside of my profession and I'm learning too, but fairly mechanically adept. Car had been sitting idle in a field for about 12 years before we started working on getting it back in running condition again. Starts up easy and it's been running fairly well off and on, but now has a hard misfire we can't seem to get right. Pretty sure what's going on, but would like to get some experienced advice before I dive in the deep end. Engine stuff that's been done to the car (some perhaps irrelevant)...
Thanks for any and all help!
-Chuck.
- Fuel pump and filter replaced
- ECU replaced
- MAF, oxygen, coolant temp sensors replaced
- Injectors replaced
- Distributor rotor and cap replaced
- Plugs and wires replaced
- Catalytic replaced
- Fuel pressure OK - maintains about 43 psi on the rail at idle and rev'd up to 3000 rpm
- Spark OK - test light shows spark on all 4 cylinders
- Compression - 1: 182, 2: 195, 3: 167, 4: 180
- Number 2 plug fouled and wet - all others OK (see pics). Seems not to be wet with fuel as it wouldn't burn.
- Noticed after compression test on #2 steam-like vapor from spark plug hole after removing gauge.
- Very rich odor from exhaust
-Chuck.
