Please Support ExtremePSI
Please Support Rix Racing
MINT 2g Part out, Lots of Performance
Spoolin98
1,639
22
Feb 1, 2004
Easton, Pennsylvania
Im getting out of the DSM game, my loss is your gain. I have way too much invested into my car to sell as a whole so Im parting it out. They ALL have very little mileage on them so don’t low ball me or I will ignore your PM. If you are wondering how long I used a part just ask, but all have less than 20,000 miles on them, most have 7500 or less. The motor and trans are still in the car, I will start ripping it apart if I have a serious buyer for the trans or head…
I will send pictures from my phone to your phone after you PM me with your number.
If you are interested in a part it may take me time to get the part off the car so please be patient, I plan on selling things as I get the car apart. In other words Im not going to rip the whole motor apart to sell just the water pump. When I get to it I will sell it. Stay tuned for more parts, I will update as I go.
Anything you dont see just ask, I probably have it.
Engine
Fluidamper Crank Pulley $300 new from Extreme PSI asking $250
Powder Coated Black Valve Cover $80
Injen spark Plug cover, chrome $40
1g Head – rebuilt 2500 miles ago – 1mm oversized ss valves, bronze valve guides, JAM upgraded springs and titanium retainers, comp 272 cams, 3g lifters, aem cam gears. Port and polished, my machinist has about 8hrs into porting and polishing this head. He has been building race motors for 30+ years, its not a basement port job. I also have stainless steal exhaust manifold studs. Complete drop in head. BO
Cams and gears I will sell separately If I have to.
Comp Cams 272/272 intake and exhaust $300
AEM Cam Gears – Black $170
Stock 2g Radiator with stock fan, no ac fan $50
2g upper rad hose
1g lower rad hose
Used 6 bolt block, Comes with pistons, rods, crank, front case, oil pan. $350 picked up
BNIB 6 bolt ARP head bolts $90
BNIB 6 bolt ARP main studs $55
1g thermostat housing with thermostat bought new, 7500 miles on it. $50
Used Eagle H-beam rods in good condition. $200
Used Wiseco HD pisons .20 over, less than 5k miles on them. Checked out by my machinist and they are good to go. Had the sides and tops coated, cost me $100 just for the coating. $450
6 Bolt bare block $100 picked up
1990 coolant pipe for use with external oil cooler $30
Used 1g OEM water pump, still works perfect, only 7500 miles on it. $40
Used 2g aftermarket alternator. Still works perfect and looks new. $60
Motor mounts – freshly powdercoated gloss black. Front and rear are solid aluminum inserts and the side mounts are poly inserts. $150
Hallman MBC, red, comes with both springs. $80
Drivetrain
Stage 2 FWD Shep Trans with quaife LSD
Last one they ever built, has less than 1000 miles on it. Still have the receipt for it, not even done breaking it in yet. Had Reline fluid in it.
Shep 2nd gear, HD 3rd and 4th. Trans has freshly powdercoated motor mounts and shifter bracket. Shifts perfectly Asking $2500
2g vehicle speed sensor $30
Also have DDS level 2 FWD axles, one piece driver side axle. Asking $400 (half price)
ACT 2600 with just break in miles on it, approx. 500 miles. $400
ACT streetlite 6 bolt flywheel $200
Buy my entire drivetrain setup and I’ll work out a deal with you.
Practically new OEM TOB, TOB clip, fork and pivot ball with less than 500 miles on them.
Used OEM TOB, Fork, and pivot ball. Still work, just replaced because I had the trans out. BO
2g slave cylinder, no leaks, $30
2g ss clutch line $20
2g shifter cables with pressed in shifter bushings, like new less than 7500k miles on them $120
Genuine B&M 2g shortshifter $100
2g clutch master cylinder, bought about 20k miles ago, still works perfect
Turbo/Exhuast
FP Manifold $275 new from FP asking $225 shipped – can ceramic coat locally at your cost
Old School FP green with polished Compressor Cover $500, no shaft play
SBR tubular 02 Housing - can ceramic coat locally at your cost
3” FWD Turbo back SS Buschur Racing Exhaust w/test pipe. $600
Suspension/Brakes
Suspension Techniques Front and Rear Sway bars $225
2g Tein Type Flex Coilovers $1450 new from extreme psi asking $1000
Used 2g Power Slot Front and Rear Rotors with Hawk Pads, Front are for GSX calipers .Still plenty of life left on them. BO
2g Front and rear adjustable camber kit $100
OEM front wheel bearings, bought them new, less than 7500 miles on them. These are $150 each, both for $200
2g GSX front dual Piston Calipers $100
2g ss goodridge brake lines, one used the rest are new $80
2g brake master cylinder, original with 89,000 miles on it
Intake
2g dejon tool intake pipe, 3” with catch can breather and K&N filter. Freshly poweder coated gloss black. Like new $120
Dejon Tool Front mount intercooler Kit, setup for MAFT blow thru but I can add a replacement piece to run speed Density. All piping is freshly powdercoated gloss black, intercooler and pipes held 30psi during boost leak test without any issues. The intercooler looks brand new, no bent fins. Flanged for a HKS BOV.
Asking $500 for the intercooler and the piping with the couplers it came with.
Add $50 for red silicone couplers from extreme psi.
Add $100 for old school genuine HKS BOV that works flawlessly.
Add $30 for speed density tube that replaces GM MAF.
Tuning
2g v3 ECMlink Bundle $775 shipped Used for only 2500 miles This is about $950 worth of stuff, save yourself some cash and buy it from me...
95 eprom ECU
ECM link obd2 cable
Speed Density Cable
Boost Control Solenoid ( Ingersoll-Rand 3-port ) Installed but never used
GM IAT Sensor
4 Bar MAP sensor
Electrical
Auto meter carbon fiber gauges
Oil temp with sender $40
Oil pressure with sender $60
Water temp $40
Pyrometer/EGT without probe $100
Vac/Boost gauge $50
AEM Uego Wideband with sensor $120
Taylor Battery box with ground and power wire, comes with 200amp inline circuit breaker.
Fuel
FIC 1055 cc injectors, less than 7500 miles $250
Fuel lab -6an fuel filter, less than 7500 miles $70
-6an SS fuel line from tank to fuel filter, must have -6an fuel filter to use $100
Aeromotive -6an FPR with liquid filled gauge $120
Walboro 255 $70
Black AEM fuel rail with -6an fittings $130
Exterior- All in excellent shape, some minor flaws. Majority of this stuff I will not ship, must be picked up in person.
BNIB Sparco Hood Pins $30
2gb Headlights, one broken tab, not in the greatest shape but can be cleaned up $40
2g brake lights
2g red hood
2g red fenders
2g red doors with tinted glass
2gb redwing
2gb red hatch with tinted glass
2g sunroof
Complete 2gb eclipse conversion. Front and rear bumpers, side skirts. Quick release front bumper installed. 2gb headlights with HID’s installed, brand new reverse lenses. The headlights are practically flawless, been garage kept its whole life. Powdercoated gloss black mounting brackets for under the hood inbetween the headlights $1500 for everything
Interior- All interior parts are near flawless. Very nice doors and perfect dashboard.
A pillar 3 gauge pod
2g wire harness
2g door panels
2g dashboard
2g center console
Custom carbon fiber insert gauge pod where the stereo goes, holds 4 gauges and 2 switches
2g sun visors, drivers side has homelink buttons for opening garage doors
All other interior parts are for sale
Hey y
Engine
2g upper rad hose
1g lower rad hose
Drivetrain
Turbo/Exhuast
Suspension/Brakes
2g Front and rear adjustable St
You still got the camber kit for sale ? For any chance or where can I get one ??
