Please Support STM Tuned
meth check valve
Tooltrt87
98
Feb 13, 2010
Ticonderoga, New_York
Hey guys I'm currently assembling a meth injection kit. I am following this site for building the kit.
Do It Yourself Water Alcohol Methanol Injection | Parts List
I have researched every part I need to build this kit and I am unclear on one thing, the check valve..
the write up explains i can use a solenoid but also mentions the check valve and i would like to go the check valve route.
I know Devils Own and a couple more kit manufacturers make there own check valves but I found this on Mcmaster carr.
McMaster-Carr
My question is simple, will this work fine for my setup? This is my very first meth kit and i would like to be certain that the check valve under the link i have provided is OK, and maybe someone with experience has used this valve before or maybe even a different one from Mcmaster carr.
Help would be greatly appreciated!!
Looks like the old coolingmist check valve. If you are looking for something cheaper, the cumminsforum.com has some info on cheap check valves, but don't remember from which site.
