donniekak
DSM Wiseman
- 5,714
- 1,062
- Mar 23, 2008
Surprise,
Arizona
If you aren’t aware of issues with single plate clutches at high rpms you’re either new, or don’t pay attention.I didn't miss any point. Singles are good for up to a certain point then they must be changed for something that can hold more torque and you're right that is 99% of the DSMs out there. I am not aware of people complaining that quick shifting a single disc is a problem, but neither a twin nor a single can shift faster than the other, that is a push. I figured out long ago about getting the disengagement correct resulted in accurate fast shifts, heck Jacks put up a bunch of videos a Looooong time ago about this issue and clutch drag which are related. Carry on.
Also, plenty of people have run 9’s, and even 8’s with a single plate clutch.
There are single plate setups that hold 700+ lb/ft. The issue up until recently was that trying to get them to shift at 9,000+ rpms was almost useless.
The op and myself must have just put countless hours of work into fixing a problem we didn’t really have.
