jdblood202
- 70
- 9
- May 18, 2013
Hampton,
Virginia
Well. I bought a "built" shortblock from a member here, I know, I really should have checked this when I bought it. I was short on time and rushing a little though so it's my fault. The block was allegedly used under 8k miles in a 500hp build. Weisco pistons, Eagle rods, ACL bearings.
I was actually about to use it, decided to pop the main caps and take a look at the bearings, (future notice, do this before I buy a motor next time), and I need advice from someone a bit more experienced in motor building than I am. A couple questions I have, is this "normal" wear or is there something wrong that needs to be addressed? What do I need to do to fix it, obviously new bearings, I'm assuming crank will need to be machined? Also, one of the rods had a bit more side to side play than the others, I measured it, and it's right at the service limit. Do I need a new rod? How does that happen? Anyways, I'll post the pics I took, I didn't pop the rod caps off, I'll do that later.
