dsmusmc
- 422
- 1
- Oct 1, 2007
Alliance,
Ohio
Brand new never installed or ran 2.2 engine. Everything is ready to drop in and go.
4G63 6 bolt block with new freeze plugs
ARP head and main studs
Race balance shaft
OEM Mitsu oil pump with polished gears
OEM Evo3 water pump
Magnus 92mm billet crank (micro polished)
Magnus/Ross 9:1 pistons (ceramic coated)
Crower I beam rods with 22mm wrist pins
ACL race bearings (ceramic coated)
Kiggly main griddle
Fulidyne crank pulley
2G head lightly ported/polished with 5 angle job
Supertech valves
Supertech valve seals
Kiggly beehive springs
Kiggly HLA pressure regulator
GSC s3 cams
AEM cam gears
Buschur coil on plug
Felpro head gasket
Kevlar timing belt
Powdercoated valve cover with -6 fittings
OEM oil pan
And of course all the macine work involved. . .
Everything is brand new and ready to bolt in and go. Rotating assembly balanced for 9K+ shifts. No expence was spared. PICK UP ONLY in Indianapolis,IN.
$5,500
Race balance shaft
OEM Evo3 water pump
Kiggly main griddle
Supertech valves
GSC s3 cams
AEM cam gears
Felpro head gasket
Kevlar timing belt
OEM oil pan
$5,500
