buhay6
- 1,661
- 63
- Jul 9, 2010
Delisle,
SK_Canada
I got a 6 bolts fidanza flywheel already so no worries there. I do how ever still need a lower timing cover, i seem to have misplaced the one i had set aside for it.
Note: This feature currently requires accessing the site using the built-in Safari browser.
Your right Brandon it wasn't actually Precise engines fault, they actually just told me its very common now a days for piston manufactures to run looser ring gaps they're seeing it all the time. I just got my block back from them an hour ago with my specs all measured and block re cleaned. The bores and piston to wall clearances are right where they should be.did you check the bores? i find it hard to believe any professional shop would bugger up the bores. id think more likely the rings are to blame. check the bore size
