420a-t
- 609
- 3
- Jun 13, 2005
Idaho Falls,
Idaho
That's true. I was speaking more in the means of putting a 1g head in a 2g. I guess I should add that since Andrew has a 1g. Thank you
Note: This feature currently requires accessing the site using the built-in Safari browser.
I don't understand? How does using a 7.81 or so compression stock 1g piston in a 2.4 block raise the compression? Is it the long stroke? If it is how does it go from 7.81 all the way to 11.1? Thats really really high? I don't think those numbers are correct. I'm sure i am wrong but that seems really high. Did they build any turbo 2.4 over seas? How about the turbo dodge srt4 piston is it possible they will interchange? Just thinking?
if you want to go higgher compression just buy the stock rods and pistons out of a g4cs motor. it will net you about 12to1 compression. i have the set from my motor in my storage. id sell you the set for $100. its the six bolt 1g big rods too. PM me if your interested.
