Please Support Kiggly Racing
Please Support Rix Racing
For Sale Local parts for sale or trade.
4gfun
Supporting VIP
2,009
55
Dec 10, 2007
Ask Me, Virginia
I have some parts that I'd like to sell or trade locally due to the risk of doing so online.
It pains me to even write this since no one ever posts here, but I figure I'd try.
I am going to post this in the DC and Richmond forums since I am in the Fredericksburg Area. I can meet around the Quantico MCB during the week to perform a trade or sale at my home in the Fredericksburg area. Generally not willing to drive to the Richmond Area to trade for small items.
I will update this list with parts that I have and parts that I want. It will start small and grow.
Thanks for looking.
Have for Trade or sale:
2 1g 91-92 FWD transmissions one good but 5th gear needs to be installed and one bad.
1 1g AWD transmission good but 5th gear needs to be installed.
rare 93-94 FWD axle set.
14b Turbo with no hot side. (Not sure if good, didn't notice shaft play).
TurboXS MBC
DNA Motoring MBC
Autometer Boost Gauge
SAFC (SOLD)
ARP Head studs for 6 bolt...installed but never run. $80
Profec B Spec 2....only the controller and the harness coming from it.
1g interior parts (poorly painted and paint peeling off).
1g Turbo EPROM ECU, unsocketed....good shape. (SOLD)
1g Turbo EPROM ECU, socketed works fine except inaccurate Coolant Temp sensor when using MMCD...traces repaired...not in great shape.
1g Turbo NON-EPROM ECU...needs all new drivers, once replaced the ECU will be fine.
1g Turbo EPROM ECU, socketed....all screwed up...broken traces galore.
Moates Ostrich v1.
2G EM Ported (has hole for EGT probe that needs to be plugged if not used)
1g TB Elbow
2g TB Elbow
1g Throttle body parts
1g Punishment Racing SMIC setup. (missing a few fittings and clamps).
Knockoff HKS SSQV.
1g long tube FMIC.
New Moog tie rod ends
XTD Stage 4 Clutch, Pressure Plate and Lightened Flywheel...unused...open box. 93-99 7 bolt FWD only. $230
Knockoff 1g Ebay Mishimoto radiator $80
Bad 1g 7 bolt Cylinder head...no compression on cylinder #1. Includes HLAs and roller rockers along with cam caps in the correct locations. Not including cams. Might have been a stuck HLA causing this but no guarantees. When scoped, cylinder #1 was stuck wide open due to some "metal flashing" holding it open. I have not been able to duplicate the problem but it doesn't mean the problem is not there. The flashing was gone when I pulled the head $150
I don't have any interior parts to trade, but what would you want for the Punishment Racing smic
setup?
setup?
Do you have anything else to trade? I'll take money, but that is a last resort.
I have a couple awd transmissions, a transfer case(all 23 spline) and a driveshaft. I may be able to locate that taillight for you.
The taillight would be terrific if you can. Thanks for bringing up the items. Turns out that I am set with AWD transmissions already.
If you had said FWD a month ago, I would have jumped on it. Ended up getting a FWD from Miller Imports shipped from NC.
Parts have been and are scarce around here.
Went to the local junkyard to check on the taillight but it was a 1ga laser and it was broken anyways. The interior is pretty damn cherry though (grey cloth).
Which junkyard? just picked up a 91 talon and it has leather seats that are beat all to hell
Penny's in Woodbridge. It's a 2.0 n/a automatic. Believe the only thing missing in the interior is the radio(who cares) and the radio trim ring(I snagged that last year along with the prop valve and front brake lines).
I know exactly where that is thanks for the info, is there anything I can grab for you? let me know ill be going tommorrow
I'm good. I found my non cruise throttle cable at another yard. ive gotten some deals there and the owner(Richard I think) is usually pleasant and easy to deal with compared to other yard owners in Woodbridge. Just stop by the office and locate the owner or they get pissy.
Thanks for trying....at least you all can still find things up there!
I got the driver seat out of the laser, 40.00 not to bad rails are trash but mine will work, they have 3-4 2gs aswell
Finding a 1.8 is a bi*** though. I'd have to check the yards out on route 1.
please forgive me for this but the laser I took the seats from had what looked to be a single cam engine? what liter is this, for some reason I thought the 2.0 NA motor was standard if not turbo?
I may be wrong but I thought that laser had a 2.0. Don't quite remember I know it had cruise control. The base model 1g T/E/L's had a 1.8 single cam.
What year is the trans from? Manual? Where are you located?
Don't know the year. They are 1g 23 spline manual awd transmissions. I'm in the Woodbridge area.
anyone have or seen a 02 housing that has a wastegate option on it?
No, but how on earth did you find a 1g DSM of any kind in F-berg? I have not seen anything in any yard for at least 5 years.
Oh no I picked my car up in Ohio. Although wide water had a black 1gb not long ago unfortunately they are short lived and crushed not long after getting there.
Still have any parts for sale?
I think that I have most of the stuff on this list. Do you have anything to trade? I am able to meet outside or in Quantico MCB these days. DC is too far at the moment.
I ended up using the drivetrain and engine out of my gsx to get my VR4 project going so I have the roller sitting around and don’t mind pulling parts off it, most if not all of the interior is there. Was wondering what exactly are the gvr4 headlight parts that you have and if you had any other parts for the vr4 you arent using.
I ended up pitching most if not all of the headlight stuff I believe since this community slowed down and not a fan of the gvr4.org forums so it was easier to trash them.
I don't think I am going to restore either of my dsm(s) and have been casually trying to get rid if them for free with no interest. I will probably start to part those at some point.
I will try to update the thread with what I have and don't have. Work and life are totally eating me alive.
