- Thread starter
- #676
DSMunknown
- 4,109
- 39
- Sep 16, 2004
Worcester,
Massachusetts
Jim, way to come out of the woodwork and represent NEDSM
Note: This feature currently requires accessing the site using the built-in Safari browser.
If you're running link, you can go to the DTCs tab and uncheck the MDP box.
Don't know if this was mentioned before but the here is the part number for the Evo III NGK plug wires.
RC-ME86
Source was NGK.com.au
Alright guys. I just installed my evo 3 manifold and tomorrow I'm hoping to put the 1g throttle body on. All the right ups I've looked through was using to 1g TB with EGR. Anyone have good close up pictures or a link on how to run it without EGR?
What you're lacking here is context. That's a very ignorant statement because you're assuming that high-RPM flow is all that's important. That's not the case at all. I've also had both and I'd take the Evo 3 in my personal case. There are many setups that would benefit from a huge SMIM but others that wouldn't get my gain from one. Running a huge SMIM with an Evo 3 16G is just plain dumb. Why? Because the 16G's powerband falls off drastically after 6500RPM or so... which just happens to be where SMIMs begin to show their gains. However, the Evo 3 manifold would give that same E316G car nice gains throughout the entire useable powerband.I don't know why people are going crazy over this manifold. A JMF SMIM outperforms, and outflows this any day of the week and twice on sunday. I have had both.
In my case, the Evo 3 manifold is a far superior manifold to any SMIM. I run an automatic trans with a mid-sized turbo (3582HTA) and I don't use nitrous to stall up the converter. Therefore, I need as much low-end torque as possible to stall that turbo up quickly. The increased air velocity created by the 2G head and the smaller plenum and longer runners of the Evo 3 manifold creates the low-end and mid-range torque I need. It would take significantly longer to stall my turbo up with a huge SMIM and when race day comes, every precious second counts on the starting line for an automatic trans car.
The SMIMs on the market sacrifice low-end and mid-range torque for increased flow at high-RPM. The giant plenums and short runners of a SMIM are not conducive to my particular setup. Now, if I was using nitrous to stall up my converter, then yes, I'd run some brand of SMIM because the low-end and mid-range torque I used to need isn't necessary anymore and I could see gains in the high RPMs.
Next time, don't make blanket statements without context...
A JMF manifold requires moving the brake fluid reservoir, relocating the battery/running a smaller battery, and in some cases modifying the UICP which is all additional to the price of the JMF. Which, in most cases is already more expensive... Besides that, some guys like the stock look under the hood but would like something that outperforms the stock 2g IM, so the Evo III IM is the answer.
I have (2) intake manifolds that I swap out, a BJ SMIM and a true Evo III IM with a plate welded to the back to run the additional sensors for SD. I lose ~300rpm (to 30psi) going from the Evo III IM to the SMIM but average 4lbs/m more on the top end. Of course I haven't done any fair back to back comparison's so I don't go advertise the data but that's what my car's showing. If I were to ever AutoX my car I'd definitely switch back to the Evo IM but drag racing I'm never below 5500 so it doesn't matter how fast it spools.
I think the only bit I used was the one on the extension. its very important the edges are still like the leading edge of airplane wing. I was very surprised how big of a difference it made. like putting cams in for the first time. I cut same amount from each runner. I figured if they came that way from factory it should stay that way. But i think there are even bigger gains if the cuts taper larger for the deeper runners. I have seen pictures of very successful manifolds done this way including map performance EF3Care to share some more info on this plenum porting you speak of?
http://www.maperformance.com/images/D/map_EVO-IM-R3c.jpg
dont know about that. just did another one tonight and it took about two hours. came out better as well.
