1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Trouble Logging In or Staying Logged In?
    CLEAR YOUR BROWSER COOKIES! More info about this can be found here. If you still have trouble after clearing your browser's cookies and cache, reply to that thread and tell us what browser you're using and what device you're using.
Kiggly Style Modded Oil Pump Pickup Service
Posted by bastarddsm, Apr 22, 2018
Please Support STM Tuned
  1. bastarddsm
    bastarddsm Supporting Vendor
    4,200
    820
    Joined Aug 26, 2003
    Mendota, Illinois
    On kiggly's site he talks about oil systems, and how good 60's can uncover the oil pump pickup and allow your pump to suck air, and starve the engine for oil. This causes all sorts of bad stuff - oil pump failures and bearing failures. The remedy is pretty easy, cover the front half of the oil pump, the difficulty is few are equipped to do the job right. Don't let your buddy fill the pickup with slag and splatter from his Harbor Freight Flux Core Welder, send it in and let a professional do it. I'll hand form a steel cover, and then cleanly tig weld it in place. Not leaving any weld buggers to come loose and destroy your precious new motor. The service is $50 including return shipping via priority mail.
    Log in/Register to remove ads
    My DSM:
    1991 Eagle Talon N/T
    Showcar Build
    9.805 @ 144.00 MPH
    Loading...
    Teezy, b00stedtalon2, 19gsx91 and 7 others like this.
    Featured Products from our Supporting Vendors
  2. Kapok6
    Kapok6 Proven Member
    1,211
    249
    Joined Aug 10, 2004
    Fort Worth, Texas
    Nice dude! Would this work or even be able to be done on a 2g pickup? (that's what I have switched to using)
    My DSM:
    Kapok6 1991 Mitsubishi Eclipse GSX
    Street Build
    11.3 @ 130.75 MPH
    Loading...
  3. bastarddsm
    4,200
    820
    Joined Aug 26, 2003
    Mendota, Illinois
    I have no idea, haven't had a 2g pickup in my hands. It looks like this could be done on a 2g pickup. I didn't know 1g's were discontinued.
    My DSM:
    Showcar Build
    9.805 @ 144.00 MPH
    Loading...
  4. turbotalon1g
    turbotalon1g Proven Member
    799
    29
    Joined Oct 19, 2005
    Blaine, Minnesota
    What's the difference between the 2?
    Also looking at Kiggly's page he covers most of the pickup, almost reverse of what you have. I'd say after doing my own as a very novice welder, I'd happily pay your reasonable priced service.
    My DSM:
    1991 Eagle Talon TSi AWD
    Drag Race Build
    11.333 @ 119.94 MPH
    Loading...
  5. bastarddsm
    4,200
    820
    Joined Aug 26, 2003
    Mendota, Illinois
    No real difference between mine and the picture on kiggly's page. He just covered more of it than I did. His probably will keep the pickup covered under a harder launch than mine. I covered less as I wanted more screen exposed for oil flow. Mines been tested for 3 seasons without flaw. I will gladly cover more of the pickup if requested.
    My DSM:
    Showcar Build
    9.805 @ 144.00 MPH
    Loading...
  6. lasthope05
    lasthope05 Proven Member
    842
    176
    Joined Mar 31, 2006
    Philadelphia, Pennsylvania
    You could probably cover up over 80% of the screen and still be fine. Have you ever seen an evo pickup? They have a tiny inlet.
    turbotalon1g likes this.
  7. Archer Fabrications
    Archer Fabrications Supporting Vendor
    6,055
    812
    Joined May 9, 2011
    Scottsdale, Arizona
    You could use an evo one and it would probably be better. Just cut and weld. Already has a pickup design similar to kiggleys method
    My DSM:
    1999 Mitsubishi Eclipse GSX
    Drag Race Build
    11.128 @ 132.5 MPH
    Loading...
  8. OH91awd
    OH91awd Proven Member
    291
    114
    Joined Sep 22, 2011
    chillicothe, Ohio
    hmmmmm... might have to send you one soon for the motor im gonna put together.
    My DSM:
    1992 Eagle Talon TSi AWD
    Drag Race Build
    10.89 @ 125.67 MPH
    1991 Eagle Talon TSi AWD (sold)
    Street Build
    GT35   manual
    Loading...
  9. Crackerman
    Crackerman Proven Member
    37
    8
    Joined Feb 28, 2018
    Alvord, Texas
    I'm sure I could help you out with that Ryan.
    Kapok6 likes this.
  10. tharrison365
    tharrison365 Proven Member
    44
    Joined Feb 25, 2013
    Galveston, Indiana
    Are you still doing these?
  11. guseclipse
    guseclipse Proven Member
    190
    16
    Joined Sep 10, 2010
    Paso Robles, California
    Do the 2g oil pick up tubes have this problem. The 2g pick up is longer so I think it would be harder to expose the pick up screen.
    My DSM:
    1998 Mitsubishi Eclipse GSX
    Street Build
    13.00 @ 100.000 MPH
    Loading...
Share This Page
Loading...
Log in/Register to remove this ad
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Miller Import Parts Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Tire Rack VR Speed Factory White Shed Speed
