GSX_Dan
- 138
- 4
- Jun 27, 2004
Chicago,
Illinois
So why does 1st use different combination of clutches between the D and L position according to this chart? Is it even the same gear then? Looks like both use rear clutch but the one way clutch(sprag in gearset) gets switched for Low-Reverse clutch in L position.
Does the low-reverse clutch have more durability/strength than 1 way clutch? You're supposed to use L in towing, descending on hills, engine braking, etc hard loads.
Any thoughts?
Any thoughts?
